Question on Qld Speed camera's
Discussion in 'Australian Motorcycles' started by W.D., Nov 1, 2003.
  1. W.D.
    W.D. Guest
    We don't see to many cam's out were I am, but I did see lots in Victoria
    while travelling to and from the MotoGP. They all had the box and strobe
    out, but after leaving Brisbane heading north I saw some Qld police ones set
    up. They didn't have anything outside the vehicle, and had now doors open at
    all. So my question is can the Qld speed camera's get you like that? or
    where they just slowing down traffic but parking out on the road?
    W.D.
    "DUCATI" not perfect but
    we win world championships
    W.D., Nov 1, 2003
  2. Usually they have the camera unit and a small sign outside the car. The
    sign is most often placed so that you don't see it till after you've gone
    past, although I believe that is just a tad outside the legislation. The
    car itself should also be clearly labelled - quite often it is an unmarked
    car/4WD with a large magnetic POLICE banner down the side.
    Could be what you saw was "we'll park here to slow everyone down", or they
    could be the backup for a hand-held radar that you'd already passed and not
    noticed. Could also be the camera unit and sign were just hard to spot.
    Doors closed = ready to go or the airconditioner is running... ;-]
    Julie and Deb, Nov 1, 2003
  3. W.D.
    Nev.. Guest
    The contracted speed camera operators in Victoria came under a bit of
    criticism / scrutiny last year from the EPA. Apparently people were dobbing
    them in for sitting in their parked cars on the side of the road with the
    engine running to keep the air conditioning pumping out cold air. EPA were
    not happy with this situation. Not a very environmentally friendly way of
    staying cool. If you see this occurring you should report them to the EPA.
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Nov 1, 2003
  4. W.D.
    Dale Porter Guest
    There are also quite a few roadside cameras in Victoria that don't use the old box and flash setup.
    They have a black box mounted to the front grill of the car. You're never sure it's a camera car
    until you go past it and see the front of the car.
    Dale Porter, Nov 2, 2003
  5. W.D.
    Nev.. Guest
    Look through the windows as you approach the cars parked on the side of the
    road. The camera apparatus set up inside the car in the front passenger seat
    area is usually quite obvious.
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Nov 2, 2003
  6. W.D.
    Smee Guest
    WILL YOU IDJUTS WHO KEEP USING THE POSSESIVE APOSTROPHE PLEASE STOP IT!
    cameras NOT camera's
    cams NOT cam's
    NEXT NUMBNUT USING AN INCORRECT POSSESIVE WILL GET A PADDLING.
    Smee, Nov 2, 2003
  7. W.D.
    Nev.. Guest
    Stop complaining about possessive's Smee.
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Nov 2, 2003
  8. W.D.
    Mick GS1000S Guest
    Most of the speed camera units in QLD are mounted on the front bumper bar or
    bull bar and look as if they are part of it. they have a high intensity
    strode type light as part of the unit. About 90% of the time they are setup
    to take front on photos.
    Mick
    GS1000S
    Mick GS1000S, Nov 2, 2003
  9. W.D.
    Actually, "cam's" is arguably correct when used to refer to cameras (but not when referring to cams).
    Then the apostrophe would indicate an abbreviation.....
    Knobdoodle, Nov 2, 2003
  10. Actually people are typing Cam's when they should be typing Cam`s, so that
    isn`t quite the case either Clem :)
    And Smee... you should know which apostrophe is which you teacher you ;-P
    Geoff and Jodie
    Geoff and Jodie, Nov 2, 2003
  11. W.D.
    CrazyCam Guest
    Well, if you want to be pedantic, it should be Cam's cams, cameras,
    beers, etc.... and the last time the Z50 disgraced itself, it was Cam's
    cam's bearings that seized. :p
    regard's,
    CrazyCam
    CrazyCam, Nov 2, 2003
  12. W.D.
    Doug Cox Guest
    You wont see that in any of my post's...
    Doug Cox.
    Work to ride, Ride to work...
    Doug Cox, Nov 2, 2003
  13. W.D.
    Eh?!!?
    There's TWO apostrophes?!!???
    Worlds are colliding Jerry! (This is like finding out Zebee has an evil twin!!)
    Clem
    [where's my Bex?]
  14. W.D.
    conehead Guest
    If you're going to abbreviate a word, smee, you use an apostrophe. So that
    would make it posse'sive.
    conehead, Nov 2, 2003
  15. W.D.
    Dale Porter Guest
    Provided the camera vehicle does not have tinted rear and side windows.
  16. W.D.
    Skipper Guest
    And also they have a new unit that is dash mounted on trial too so it is portable.
    The exception to what Mick said is most of the cams here in Qld are going to IR now
    so they don't need a flash, or at least not a visible one anyway.
    Doug.
    Hi Mick, long time no see, been busy? Chatted to Triffid lately?
    Skipper, Nov 2, 2003
  17. W.D.
    Mick GS1000S Guest
    I've been very busy. I finally have the S running nicely and took it for a
    very short ride around the block this afternoon. I still have a few things
    to sort out on it before its ready to go back on the road. My main problem
    with it is going to be getting the gearing tall enough to keep the bloody
    front wheel on the ground.
    I haven't seen or heard from triffid
    Mick
    GS1000S
  18. W.D.
    Smee Guest
    The paddle's working overtime.
    Smee, Nov 3, 2003
  19. Nev.. said....
    Ne> Stop complaining about possessive's Smee.
    Hmm. Someone who want's a paddling......
    Martin Taylor, Nov 4, 2003
