question about long trips
Discussion in 'Motorbike Technical Discussion' started by David Allen Trimm, Jun 25, 2004.
  1. I took a ride from San Diego, CA to Quartzsite, AZ, and then to Parker, AZ
    all in the same day. On my way back, more than half way, I experienced a
    nose bleed that lasted for about 2.5 hrs. I had a full face helmet to go
    out there, but had a half shell - open face for the way back. Was this
    bloody nose caused by the helmet being open and wind entering my nose or
    something else. Any thoughts would be good, I thought the bleed lasted too
    long to be ignored. I have not had any problems since my return, with the
    exception of sleeping extreme amounts of time. I took this trip on Mon.
    Got back in San Diego on Tues. Slept for 15 hrs straight Tues-Wed. Slept
    12 hrs straight Thurs.
    thanks
  2. don't really have high blood pressure that I know of. used to have a
    problem when I was overweight in high school, but I keep my weight
    reasonable these days. I don't have any known health problems. don't get
    sick but once in a great while.
  3. The dry desert air will dry the lining of your nose out and cause it to
    crack. Eventually, your body adjusts. Drink lots of fluid - if you're
    dehydrated, your mucus membranes are drier than if you're correctly
    hydrated.
    Been there, done that. Definitely not fun.
    -Andrew
    Andrew Szafran, Jun 25, 2004
  4. David Allen Trimm
    Steve T Guest
    :Drink at least one fluid ounce of
    :water for each pound you weigh for NORMAL physical activity. For a ride
    :like that, you need lots of h20.
    You want me to drink 195 ounces of water???? Give me a break.
    Steve T, Jun 25, 2004
  5. <G>
    The Older Gentleman, Jun 25, 2004
  6. Parker is about 30-40 miles due north of quartzsite, right along the
    colorado river.
  7. One day in rec.motorcycles, Also Sprach Steve T:
    Heh... he likes to watch...
    Vic Sagerquist
    aa#2011
    Supervisor, EAC Department of little adhesive-backed "L" shaped
    chrome-plastic doo-dads to add feet to Jesus fish department
    ______________
    It's my funeral and I'll fry if I want to...
    Vic Sagerquist, Jun 25, 2004
  8. David Allen Trimm
    JD Guest
    I almost always have a nosebleed problem in the winter time from the dry
    air, doctor told me to dip my fingers in vaseline then poke them up my nose,
    so the membranes won't dry out. Usually the nosebleeds only last a couple
    minutes but after a 1-2 hour long nosebleed ordeal (resulting in something
    resembling my spleen that came out of my nose near the end) I finally
    thought I should go to the doctor.
    JD, Jun 25, 2004
  9. David Allen Trimm
    Polarhound Guest
    2.13 gallons of water is a bit much for me too..
    Polarhound, Jun 25, 2004
  10. David Allen Trimm
    Polarhound Guest
    Drink plenty of fluids, and use a saline nasal spray.
  11. Your spleen came out your nose? Damn, my spleen always comes out of
    my mouth, and then only when I've been drinking tequila.
    Carlin Hagerty, Jun 25, 2004
  12. David Allen Trimm
    N0EQL Guest
    What kind of gallon do you use?
    1 Gallon = 128oz. 195/128= 1.55 gallon.
    That does not sound excessive to me taken over the course of an 8 - 10 hour
    ride.
    It is not uncommon for me to drink a quart of water before a ride and a
    quart at the end of my ride. That leaves 4 quart during the day or 1 quart
    of water for each tank of gas.
    N0EQL, Jun 25, 2004
  13. Not in the UK. 160oz.
    Stephen Malbon, Jun 25, 2004
  14. David Allen Trimm
    Mark Olson Guest
    So, a US ounce isn't equal to a UK ounce, either, that's interesting.
    160 / 128
    1.25000000000000000000
    Google says:
    1 Imperial gallon = 1.20095042 US gallons
    Google also says:
    1 Imperial fluid ounce = 0.960760333 US fluid ounces
    <Ed McMahon>
    "I did not know that"
    </EMM>
    Mark Olson, Jun 25, 2004
  15. All depends on what you're doing and how ya drink it, I suppose. My
    personal record would be 22 qts(I think a standard military canteen is a
    quart) of water in one day.
    entropy_magnet, Jun 25, 2004
  16. Hydration (which about everyone has already mentioned is probably the
    problem).
    You lose/use fluids quicky on a motorcycle. Whenever I go on a long
    trip I use:
    http://www.bagking.com/Merchant2/me...D&Product_Code=Hydrobak&Category_Code=03-Road
    Hydration backpacks are great. They let me drink when I want to
    rather than having to pull over for an otherwise unwanted break, or
    chugging my fluids down at a Gass stop.
    wrestleantares, Jun 25, 2004
  17. Maybe he weighs 273 pounds?
    One quart per tank is about right, at the very least a pint. Make
    your stops at the gas station also a stop for water. This advice
    varies by climate, of course, but this time of year riding in Arizona,
    you would be well advised to do the whole quart on every stop. Make
    it Gatorade every other stop.
    To OP, you live in San Diego. You rode into a much drier climate at
    somewhat higher altitude. For all readers, remember that at high
    altitudes, you are much more susceptible to UV radiation. Sunburn
    happens fast up here, and dehydration is not fun. For me, it takes
    the form of cramping chest pains. Ouch! Remember that diuretics like
    coffee exacerbate the problem.
    Al the Equestrian, Jun 25, 2004
  18. Eyedrops are also a good thing to have along on a long trip. Couple
    o' drops at every stop does wonders for eye fatigue.
  19. David Allen Trimm
    Bownse Guest
    What were you doing to stay hydrated while riding?
    Bownse, Jun 25, 2004
  20. David Allen Trimm
    Bownse Guest
    In August of last year, I went through 4 gallons of water in 1 24 hour
    period without any additional bathroom breaks. That desert heat (it was
    over 110 in SLC) can suck the moisture right out of you.
