question about CV carb setup
Discussion in 'Motorbike Technical Discussion' started by Dave, Sep 24, 2007.
  1. Dave
    Dave Guest
    Bike is a 1980 XS650.
    Decided to check/adjust/synch the carbs this weekend. The bike has been
    running good, just decided to see if I could make it run even better and get
    a bit more power. I had read that the easiest way to set the idle mixture
    is to take out one plug and ground it against the engine, then start the
    bike (which will run on one cylinder ok) and adjust the carb on the running
    cylinder to achieve highest smooth idle. As the idle mixture screw on these
    carbs is a GAS screw, not an air screw, I figured that the more I turned it
    in (clockwise) the higher the bike would idle as the mixture leaned out.
    BUT... what I saw was the opposite. I started about 2.0 turns out, then
    turned it CW in 1/4 turn increments. The rpms dropped. And dropped. And
    dropped. And finally stalled about 0.5 turns out.
    So, what I ended up doing was watching the tach and opening the mixture
    screw until the RPM maxed out and leaving it just at that point. Did the
    same to the other one, then synched the carbs. The bike runs no better and
    no worse than before which, I suppose, could be a lot worse.
    Am I missing some key concept here? Should I have done it with both
    cylinders firing? How can the engine idle slower with a leaner mixture?
    As a secondary issue, I am thinking about re-jetting for more top-end power.
    I am used to riding a sportbike and like the upper range power when I'm on a
    curvy and/or uphill road. This bike is good on acceleration from 0-60 but
    absolutely sucks from say 60-90. Very little power. Would larger main jets
    likely help me out here or am I wasting my time on an old bike that ain't
    going to go any faster?
    Thx
    Dave S.
    Dave, Sep 24, 2007
  2. Dave
    . Guest
    So, what size pilot jets do you have?
    XS650SE's imported to the USA had very small #27.5 idle jets which
    might require the idle mixture screws to be opened 3.5 turns.
    XS650G's imported to the USA had whopping big #42.5 idle jets that
    might require the idle mixture screws to be closed down to 1/4 turn
    open or less.
    I wouldn't adjust a carburetor unless both cylinder were firing,
    because the dead cylinder would still be sucking gasoline and that
    would wash the oil film off the cylinder wall and it would also dilute
    to oil
    The mixture was too weak to provide the minimum amount of power
    necessary to
    sustain the idle at the desired RPM.
    Have you checked the cranking compression? If the cylinders have low
    compression, below 150 psi or so, the motorcycle won't achieve its top
    speed, no matter what you do to the carbs.
    Have you done a plug chop after a high speed run? What did the
    porcelin insulator inside the plug look like? If you're running
    unleaded gasoline, you should see a narrow ring of fluffy black soot
    deep inside the spark plug, where the porcelin meets the steel shell.
    If only the nose of the spark plug is white and free of soot, the
    mixture is too rich and the engine is running too cold to develop
    maximum power.
    For more information on rejetting, go to www.factorypro.com and read
    the articles on CV carb tuning and mainjet selection for low RPM
    engines.
    Steer clear of Dynojet's bullshit about making your carburetor's
    various circuits operate independantly and avoid the temptation to
    dick around with raising and lowering the needles.
    Understanding how the idle circuit operates is key to understanding
    the CV carburetor.
    ., Sep 24, 2007
  3. Dave
    Dave Guest
    It's an XS650G, Canadian model (speedo in km/h) with the adjustable needles.
    I don't know what size the pilot jet is I'm guessing it's completely stock
    but haven't disassembled the carbs to date. The stock anti-smog factory
    setting was about 2.0 and the best idle was achieved at about 3.0 turns out.
    No, I haven't checked it. I have a compression tester but it never occurred
    to me that I'd have a compression problem given that the engine's only got
    20K miles on it. I'll check, only takes a minute.
    Didn't look inside the plug. I have checked them, they're nice tan color,
    no soot apparent but as I said I wasn't looking for any small ring of soot.
    I've read it, I was hoping that somebody with a similar bike might save me a
    whole lot of time and effort trying different sized main jets... there are a
    bazillion of these bikes on the road.
    I thought I had a pretty good understanding, hence my confusion about the
    idle going down and not up as I leaned out the mixture. I'll try it again
    with both cylinders running, I think the drag of the operating cylinder just
    took too much power to accurately set the other carb.
    Dave, Sep 24, 2007
  4. Dave
    ? Guest
    So you probably have the #27.5 idle jets. Back in the days of slide
    valve carbs, you would see round idle jets that were about #30, and
    round main jets up to #150, because the engineers expected the rider
    to use a lot of throttle and didn't have to worry about keeping the
    atmosphere clean.
    Modern CV carbs take direct control of the main jet out of the rider's
    hands and they now use a much larger idle jet to give the engine good
    off-idle and midrange performance without ever having the carb go onto
    the main jet.
    The size of the orifice is based upon a #100 jet having a hole that's
    1.00 mm in diameter, so a #42.5 pilot jet has a hole with an area 2.4
    times that of the #27.5 jet.
    And, remember that the screw-adjustable idle mixture outlet is only
    one of four idle mixture ports in the carb throat. When the idle jet
    is large, more mixture will flow through the three transition ports
    controlled by the throttle butterfly and you have to turn the mixture
    screw all the way closed.
    Besure the engine is warmed up and open the throttle all the way so it
    can get air to compress. The compression pressure should rise evenly,
    over about five compression strokes.
    If you're running unleaded gasoline, a tan insulator indicates you're
    burning a little oil. A wet ring around the threaded end of the plug
    indicates you're burning a lot of oil, as does shiny black carbon
    burned onto the ground electrode right where it's welded to the outer
    shell.
    #135 main jets are plenty large, if you're not running an open exhaust
    system. Remember what I said about the main jet size being based upon
    1.00 mm. If you go from a #135 to a #150 jet, the bigger jet has 1.24
    times the area of the smaller jet, and you probably don't need
    anywhere near that much orifice area if you're just trying to optimize
    the performance of an engine.
    Well, tuners have understood for a long time that there was more power
    to be extracted from an engine by leaning up the mixture, but you will
    always hear amateur shade tree tuners talking about throwing a jet of
    larger jets into their carbs to extract some more horsepower that the
    engineers at the factory stupidly overlooked.
    The actual reason that racers put larger jets into their carbs is to
    keep the engine cooler by reducing the temperature that the fuel/air
    mixture burns at. If you're not going to be running at full throttle
    on some long race track somewhere, chances are you don't need bigger
    main jets, you just need to work on the idle mixture circuits by
    optimizing the idle screw settings.
    If you have to adjust the idle mixture screw more than about 3.5 turns
    open with the small idle jets you have installed, you can put some
    #30's or #32.5's in there.
    But you might just be chasing a rule of thumb by doing that. How much
    effort and expense do you want to invest in chasing a rule of thumb?
    ?I'll try it again
    That's what I was trying to say in the previous post.
    ?, Sep 24, 2007
  5. Dave
    Dave Guest
    According to the manual, I've got #132.5 main jet, #85 air jet, #135
    throttle valve, #42.5 pilot jet, and #30 starter jet. Don't really
    understand the difference between pilot jet and starter jet, unless one of
    them has to do with the choke (okay, okay, "enricher circuit").
    Well every year it gets closer and closer to an open exhaust system as rust
    eats more holes in the mufflers. I tried several retail muffler repair
    "systems" and found that they're all junk. Don't really want to sink $250
    into mufflers to go on a $250 motorcycle.
    Last year I tuned a Honda CB750 for a friend who couldn't get it to idle
    smoothly... the previous owner had drilled some "extra" holes into the
    airbox: bypassing the air filter. Duh. Those Honda engineers really
    dropped the ball on that one!
    Yeah, I know what you mean. I just don't think there's much more
    performance to be had out of this old dog. I'll check the compression just
    fer fun; other than that it's likely as good as it's going to get. I
    shouldn't be going that fast on this bike anyway... the handling and braking
    are not confidence-inspiring after riding my VFR.
    BTW, you said tan=oil burning. This bike doesn't burn appreciable amounts
    of oil (although it does seem to drip it in my garage from the clutch
    pushrod seal and main crank seal). I was always told that you want your
    plugs with "a layer of light tan ash" on the porcelain... white or grey
    meant too lean/hot, black soot too rich.
    Dave, Sep 24, 2007
  6. Dave
    Guest Guest
    Yes, the starter jet feeds gasoline straight out of the float bowl to
    the bypass passage when you "choke" the engine.
    Drilling large holes into an airbox ruins it as a resonant chamber.
    When I remove the 3-inch long rubber snorkel from the airbox on my
    GS1100, it started lean surging violently at 6000 RPM, which was 100
    mph in 3rd gear. I reinstalled the
    snorkel and the surging was gone. I removed the airbox cover entirely
    and the engine didn't surge. But the engine really hated having to
    suck air through the hole where the snorkel had been when i removed
    it.
    That tuning "secret" is now 30 years out of date, now that tetraethyl
    lead is no longer used to raise octane.
    How wide should the narrow band of soot inside your spark plug be?
    Keep leaning the idle mixture until you start seeing small black
    specks that look like crains of pepper on the insulator nose. That is
    carbon that is flaking off the top of your piston, and watching for
    this evidence of lean mixture preignition works fine on old engine
    with carboned up pistons.
    You'll never see the specks on a newly-built hot rodded engine though.
    But you might notice the strange groaning sound that an exhaust system
    makes when the engine is jetted too lean and the crackling sounds out
    exit of the pipe.
    Older 2-valve per cylinder engine designs gave the burning gasses more
    time to
    transfer heat to the crown of the piston and the ignition had to be
    advanced to over 50 degrees BTDC in some inefficent designs which
    didn't swirl and tumble the fuel air mixture and vaporize it.
    Modern 4-valve per cylinder engines reduce the total number of
    crankshaft degrees that the engine uses to light the mixture and
    extract most of the usable power from the expanding gasses by about
    30%.
    So the later designs don't need to waste so much fuel to cool the
    combustion process and the engines can be jetted leaner.
    Guest, Sep 24, 2007
  7. Dave
    Dave Guest
    Okay, so I'm looking for white porcelain with a band of black soot near the
    bottom of the insulator in the groove between the insulator and the external
    metal case.
    Are we still talking WOT plug chop? Or low-speed cracked-throttle chop?
    How much do the idle jets contribute to the wide-open performance? I guess
    that'd be about 9.3% based on areas of the jets. More than I thought it
    would be before I did the calculation.
    The black specs, are they a good thing or do I want to richen it say 1/4
    turn after I start seeing them?
    This is starting to sound more like art than science. I adjust the idle
    mixture for full-throttle performance (!) and hope it will idle at all with
    the throttle closed? I'm sure it will, I was very surprised that I could
    basically go from 0.5 to at least 5 or 6 turns and the bike still ran. Then
    you hear about people talk about things like richening the idle for better
    "off the throttle response". I guess the key is to just mess with it until
    you get tired or find that nirvana which is optimum jetting and mixture
    adjustments.
    Thanks for the help.
    Dave S.
    Dave, Sep 24, 2007
  8. Dave
    ~ Guest
    Nothing. The vacuum downstream of the wide open butterfy is too weak
    to suck mixture out of the idle circuits.
    When you read performance tuning instructions for carburetors, the
    authors alway make it appear that the idle mixture ports only operate
    from
    closed throttle to 1/8th throttle and then the throttle slide cutaway
    supposedly starts helping acceleration, and then in their fantasy
    world the carb supposedly runs on the needle until the throttle is 50%
    open, then they clain the carb runs on the main jet.
    And all the above is a steaming pile of capital-C Crap. The various
    fuel/air circuits of a carburetor overlap, the idle circuit provides
    less and less fuel/air mixture as the throttle opens further and
    further and the slide raises more and more.
    An increasing amount of fuel/air mixture passes between the jet needle
    and the needle jet tube that it goes up and down in, but this amount
    of fuel/air mixture is less than the amount of fuel/air mix that could
    pass through the main jet, once the needle has raised high enough so
    the difference in area between the jet needle and the needle jet hole
    is larger than the orifice hole in the main jet.
    At some point, around 50% of the possible distance the slide can
    lift?the jet needle/needle jet combination orifice begins to pass more
    fuel than can pass through the idle jet.
    This is called the "cross over point", where the engine is getting
    more fuel through the JN/NJ than it is getting through the idle jet.
    Although your idle jet can only pass about 10% of the amount of fuel
    that the main jet can pass at full throttle, your carburetor is still
    running on the idle jet 75% of the time, until you open the throttle
    so far it lifts the slide all the way.
    GOK what the slide position is at any given time in a CV carb, but
    once it has lifted the slide all the way you're theoretically on the
    main jet if the carb is jetted anywhere close to where it should be.
    When I see the specs, I richen the mixture slightly.
    It is an art. ?
    No, no. Remember the pattern of three transition ports below the
    throttle butterfly? If you open the idle mixture screw, you are only
    adjusting the fuel air mixture through ONE port, about 3/4ths of an
    inch downstream of the transition ports.
    The transition ports are NOT controled by the idle mixture screw in
    any way. Where the amateur mechanic gets into trouble is when he turns
    the idle mixture screw too far counterclockwise and the idle mixture
    coming out the single port becomes too rich.
    The exhaust note becomes dull and thudding, the exhaust smells too
    rich, the engine idles too slowly and maybe stalls.
    So the amateur mechanic turns the idle speed knob up to get the idle
    speed back to spec. This opens the butterfly slightly, uncovering the
    first transition port.
    When he blips the throttle, checking for throttle response, he is
    surprised by the engine's refusal to idle down again. The amateur
    mechanic is utterly lost at this point, because he doesn't even know
    the transition ports are there to help the motorcycle accelerate away
    from a stop.
    The transition ports are NOT supposed to be uncovered at ordinary idle
    RPM when the tranmission is in neutral. They pass too much fuel for
    the amount of power needed to idle the engine.
    The idle screws weren't adjusting anything at all after 4 turns open.
    Opening the idle mixture screws 1/8th to 1/4 turn past the EPA setting
    will definitely help the engine start and warm up quicker and
    accelerate better at small throttle openings.
    No, the key is to understand how the carburetor works. Mark Salvisberg
    has a wonderful site at www.factorypro.com, but Dynojet has a site
    that is full of capital-C Crap with their claims that their kits will
    seperate the interacting fuel/air mixture circuits into "discrete"
    circuits like some old slide valve mixer of yesteryear.
    Dynojet claims that carburetors need to be tuned for "dynamic"
    performance (when the engine RPM is changing rapidly) as well as for
    "static performance" (when you are trying to cruise or corner at a
    steady speed).
    I bought exactly ONE Dynojet kit, and it didn't help my GSXR750 one
    pit, it actually hurt the performance during steady speed cornering. I
    called up the tech rep and asked him what was going on, and he told me
    that I should be able to accelerate rapidly through the terrible flat
    spot in the mid range like I was street racing or drag racing.
    I told him I couldn't do that, I had to go through certain corners in
    certain gears without having to upshift and downshift in mid turn.
    ~, Sep 25, 2007
  9. Dave
    the fly Guest
    Other posters have covered the CV carbs pretty well.
    Low-speed and mid-range should benefit from some tweaking, but unless
    you add a LOT more breathing capacity, larger main jets won't help.
    The XS-650s used very modest cam lift and timing, with small
    valves. It made for good mid-range, and really good reliability. It
    was totally inadequate for "sportbike" performance.
    A friend had a BSA 650 Lightning while I had an XS-650. I
    could stay even with him to about 70 or so; then the Yamaha stopped
    pulling, and the Beezer would walk away.
    Someone else I knew explored the top end of his XS, and turned
    it into a Britbike killer, but it cost a head, valves, exhaust system,
    cam and pistons, and many portraits of Ben Franklin.
    the fly, Sep 25, 2007
  10. Coo, he's morphed again.
    The Older Gentleman, Sep 25, 2007
  11. This is a fair assessment. It was Yamaha's first four-stroke, after all,
    and they were playing it safe. The first prototype engines only produced
    something silly like 20bhp. They had a lot to learn.
    Oddly, despite being two-stroke builders, Yamaha's engineers got a lot
    of experience working on the Toyota 2000 sports car. Specifically, they
    developed the cylinder head. The valve springs in the early 650 (maybe
    the later ones too) had Toyota part numbers, and the pistons were
    modified Toyota ones.
  12. Dave
    Dave Guest
    There's a web page (650 central maybe) which has got instructions to convert
    the XS650 from a 360-degree to an 83-degree offsite firing angle. I thought
    about doing it, retooling the cam, new ignition, at that point you even
    start thinking about a retooled head with larger valves, etc. But the cost
    quickly put that idea to rest. the exhaust is, I think, only 1-1/4"
    headers, and I've also seen people who have upsized the pipes and intake air
    flow to squeeze some more power out.
    Dave S.
    Dave, Sep 25, 2007
  13. And just re-throwing the crank wouldn't improve power on its own -
    just make it smoother. As you say, you'd need to carry out all the
    tuning work after doing the crank, timing and cam changes.
    XS650s are very easy to tweak anyway, and the engine is incredibly
    strong, so you've no need to worry about blowing the thing up.
    chateau.murray, Sep 25, 2007
  14. Dave
    Dave Guest
    Ah, but if you start messing with larger valves and higher lift cams some of
    your bullet-proof-ness gets lost.
    Dave, Sep 25, 2007
  15. Believe me, an XS650 has got enough of that Magic Ingredient to spare.
