Query of Changing Engine Oil Frequency
Discussion in 'Motorbike Technical Discussion' started by NewBie, May 30, 2005.
  1. NewBie
    NewBie Guest
    Hi,
    Am I correct to say that a small cc bike engine is working harder than a big
    cc bike engine for a same distance (eg: 10,000km)?
    If the a above statement is correct, does it mean that the small cc bike has
    to change its engine oil more frequently? Lets say a 400cc bike is changing
    its engine oil every 5000km then a 125cc bike should change its engine oil
    not more than 2500km?
  2. NewBie
    John Johnson Guest
    Why would this be the case?
    Why not just follow the manufacturer's suggested change interval?
    John Johnson, May 30, 2005
  3. NewBie
    David Kelly Guest
    Define your perspective. What does "working harder" mean?
    Lets say your "little" bike has 1" bearing mains and turns 6,000 RPM
    under "normal" conditions. And your land ark super SUV has 3" bearings
    at 2,000 RPM. Guess what? The bearing velocities are exactly the same.
    I haven't had a V8 apart in a while so I'll be the first to admit that
    3" is a bit big for a consumer engine but not unrealistic in a
    commercial Diesel truck engine.
    Then considering most motorcycles have ball bearing crank mains, the
    bearing contact velocities are much much less.
    For a homework assignment try the same math on maximum piston speeds.
    As for attempting to establish an all-encompassing generic
    generalization, as others have already said, "Read your owner's manual."
    The motorcycle manufacturer has a much better grasp as to what your
    engine needs. Much better than even the oil manufacturer's marketing
    department who only wants instill fear so you will readily purchase
    greater quantities of their most expensive products.
    My GL1800 gets an oil change every 4,000 miles or 12 months, whichever
    comes first. Been riding the KTM dirtbike a lot so the GL sits more than
    it used to. The KTM RFS gets oil change every 15 hours, which works out
    to every 3 to 5 rides, or 3 to 5 washes, or 1 dirty air filter wash, or
    about the same as valve adjustment interval. The KTM gets its oil
    changed very often not because I'm worried about the oil wearing out but
    because I'm worried about the dirt and water I expose the thing to.
    David Kelly, May 30, 2005
  4. Only if the smaller engine is being used twice as hard.
    The Older Gentleman, May 30, 2005
  5. As Mark Olson says, this is complete nonsense - apart from two-strokes.
    Ball race cranks haven't really been seen in four-strokes since Suzuki
    killed the GS range and Kawasaki ended production of the
    Z1/900/1000/1100 series.
    I *think* one or two four-stroke singles have used built-up cranks, but
    ICBA to Google.
  6. That might be true of some older small bore engines of less
    sophisticated designs. Drain your oil into a clean pan. If you're
    seeing "crispy critters" in your oil pan when you change oil, go ahead
    and reduce your oil change interval until you no longer see those
    little black things...
    The comparison is too general. Maybe the 400cc engine is an older air
    cooled design with a longer stroke compared to its cylinder bore and
    and the 125 cc engine is a modern watercooled design with a very stroke
    stroke in comparison to its bore diameter...
    So you need to follow the motorbike manufacturer's recommendations for
    oil change intervals...
    One thing that you should understand about oil is that lubricating oil
    is separated from crude oil by a process of heat distillation. Since
    the engine gets hot during operation, your petroleum-based oil
    continues to distill and get thicker inside your engine...
    You want your engine oil to reach 212 degrees F everytime you run your
    engine, in order to boil off any water tht has condensed in the oil.
    Water
    in the oil combines with sulfur, making sulfuric acid that eats away at
    the parts of your engine...
    The maximum temperature that your petroleum oil should regularly reach
    is
    240 degrees F . If the oil never gets over 240 degrees, follow your
    owner's manual for oil change interval based on time and mileage...
    For every 10 degrees F over 240 degrees, you should *theoretically* cut
    your oil change interval in half, according to the motorbike magazine
    writers...
    So, if your manufacturer recommends changing engine oil every 3500
    miles, and your oil temperature gets up to 290 F, this theory suggests
    you should change your oil every 109 miles...
    There have been big bore Honda engines that regularly heated their oil
    up to 315 degrees F in the cylinder head area. Theoretically, their oil
    should have been changed every 40 miles or so, not that most owners
    ever actually
    did this regimen...
    Actually, that 315 degrees F was just local heating, whatever light
    fractions distilled out of the oil would leave waxy brown deposits or
    asphaltic black goo up under the valve cover, while the rest of the oil
    just got thicker and thicker and thicker and was more difficult to
    circulate. What an observant rider might notice at his 3500 mile oil
    change would be small black carbon particles in the oil. My friend used
    to call them "crispy critters". That suggests the oil change interval
    should be changed...
    And the magazine which suggested halving the oil change interval for
    every 10 degrees over 240 admitted that they just weren't seeing a lot
    of smoking wrecks of motorcycles abandoned along the roadside, having
    died of lubrication failure...
    krusty kritter, May 30, 2005
  7. NewBie
    Matt Guest
    .... and eats away at the oil itself, reducing its lubricating properties ...
    Matt, May 30, 2005
  8. NewBie
    Paul Cassel Guest
    You are one ignorant loudmouth and know nothing of cranks aside from
    being one. I have two current production 4 stroke bikes with roller
    bearing cranks - a DRZ and an LC4.
    You know nothing much, do you?
    Paul Cassel, May 30, 2005
  9. You really are an ignorant and objectionable twonk.
    Did you read the line you snipped?
    "I *think* one or two four-stroke singles have used built-up cranks, but
    ICBA to Google."
    Now remind me: what's an LC4? and what's a Suzuki DRZ? Oooh, hang about,
    it's coming to me...
    And if you read again the para you left unsnipped, it reads "Ball race
    cranks haven't really been seen in four-strokes....". That's an
    open-ended statement. It's not a definitive statement that they've never
    been used since the 1970s.
    Take those together and you'll see that I was, indeed, accurate and
    David Kelly was, indeed, talking utter crap.
    And yes, I almost certainly *do* know more than you.
  10. And his two examples are singles, a class of bike which I said I
    believed still do use b&r cranks from time to time.
    No, let him stick around, and let's see what other idiocies he comes up
    with. It's always fun watching people make fools of themselves.
    <Taps fingers expectantly>
  11. NewBie
    Paul Cassel Guest
    Because the asshole picked a fight with me in public. He's ignorant and
    I will point it out when I see him. Where were you when he picked his
    fight with me?
    He can fry in hell for all I care.
  12. Nope! Surprisingly orant, in fact.
    Got it wrong, then didn't you, boi? Dearie dearie me.
    Regarding you as a complete idiot?
    Sizzle! Sizzle!
    *Lovely* Thanks for that, Cassel, sweetie-pie. You've made my day.
  13. Oi! I resemble that. There was no tiff as such IMHO that implies a
    fairly even argumenbt or dispute, and I don't think there was anything
    of the kind. And certainly no rancour on my part.
    Amusement, maybe.... ;-))
    It's the "in public" bit that makes me snigger. I mean, does he think
    that Usenet is a private club or something?
  14. <Slips MO a tenner>
  15. "The Older Gentleman"
    message
    <takes tenner FROM MO and hands it back to TOG>
    I'm sorry sir is there a problem? This person has
    been standing around the front door all day taking
    peoples monies. Rather sad really, pretending to
    be the doorman we neither have nor need. 8^) The
    waitstaff and members are quiet capable of sorting
    who does and does not belong.
    Now if you'll excuse me I'll get back to drinking
    my last Sam Adams Lager of the holiday.
    Keith Schiffner
    RCOS #7
    Assistant to the Assistant Undersecretary of the
    Ministry of Silly Walks.
    "terrorist organization" is a redundancy
    Keith Schiffner, May 31, 2005
