The alternator conversion for the CBX is around 2cm longer than stock, and I have Rickman engine bars. Wot are a very tight fit already. Would it be possible (note: "possible", not "advisable") to shim out the bars with some specially made metally bits <looks at WUN> [or washers] with slightly longer bolts? The alternative would be to discard the bars, with all the messy expensive inevitability that would ensue. The rhs could remain stock, just the left side needs moving. All bolts go into the frame, except at the front where the two sides meet.
