Q's about bikes in Blighty
Discussion in 'UK Motorcycles' started by Sean_Q_, Nov 22, 2009.
  1. Sean_Q_
    that's how I interpreted it, and wikipedia is pretty reliable for this sort
    of information.
    If you dig deeper, the Mondeo platform was tried in the US and Australia
    where it flopped. Complex, and interesting stuff, the socio-economics of
    vehicle production.
    wessie, Nov 22, 2009
  2. Sean_Q_
    I've never ridden (driven?) a combination, but surely a LH chair is
    more liable to swerve right into oncoming traffig in a panic brake
    situation.
    Pip Luscher, Nov 22, 2009
  3. Sean_Q_
    You're right but I found that fitting a damper made it more
    predictable and there's nothing to stop the rider from turning into
    the chair as they slam the anchors on.
    Andy Bonwick, Nov 22, 2009
  4. Sean_Q_
    Obviously /some/ bits are different between left & right hand drive,
    but they're not going to move things like steering column stalks to
    t'other side of the column are they. Well not unless they have to on a
    particular model because a left-mounted stalk on a RHD car would
    interfere with something else when the column's moved to the left side.
    Which is unlikely as they'd design it so they didn't need to.
    Krusty, Nov 22, 2009
  5. Sean_Q_
  6. Sean_Q_
  7. <heartfelt mode>
    Oh yes.
    The Older Gentleman, Nov 22, 2009
  8. Sean_Q_
    That does look vaguely familiar but the interior was a kind of drab
    green, like the rest of the car IIRC.
  9. Sean_Q_
    Andrew998 Guest
    I do. And just what does that have to do with changing gear?
    Andrew998, Nov 22, 2009
  10. A good part of it is the ability to listen and learn. There's a
    couple of people who do track days with the PCA who just can't get any
    faster - because they won't accept that the instructor may have an
    idea worth trying.
    But, a competitive nature helps too.
    vulgarandmischevious, Nov 22, 2009
  11. I always perceived it to be the absolute opposite. When I commuted
    daily to central london, no-one on my commute waved to each other -
    and rightly so. So I'd go out for a recreational ride on a sunny
    summer sunday, and find all these weekend warrior wankers waving like
    crazy. I ignored the soppy cunts.
  12. Sean_Q_
    Nige Guest
    Only old codgers wave round here. I nod if i get nodded at, but **** me, you
    don't wave at all other car drivers ffs.
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Nov 22, 2009
  13. Sean_Q_
    Catman Guest
    Changing gear would classically regarded as either a maneuver, or part
    of one.
    116 Giulietta 3.0l Sprint 1.7 GTV TS 156 V6 2.5 S2
    www.cuore-sportivo.co.uk
    Catman, Nov 22, 2009
  14. Sean_Q_
    Tim Guest
    <Nods knowingly.>
    Yep. I can confirm that Brits really are excellent hand wavers.
    Tim, Nov 22, 2009
  15. Sean_Q_
    Cab Guest
    Listen...
    That's the sound of me not biting. :)
    Cab, Nov 22, 2009
  16. Sean_Q_
    Catman Guest
    That's cos they were couriers innit.
  17. Sean_Q_
    Eiron Guest
    Vauxhalls were on the left.
    Eiron, Nov 22, 2009
  18. Sean_Q_
    Catman Guest
    I think technically you *could* change gear without changing vector.
    Steering straight, just change revs to keep speed consistent.
    Yes, there would be a slight change of vector as you disengage drive,
    and you're unlikely to get the revs so spot on that you hit exactly the
    same speed, but it could, in theory, be done I feel.
  19. That's not all they do well with their hands or hand.
    don (Calgary), Nov 22, 2009
  20. KrustyUS morphs again ;-)
