Q: Standard Replacement for Yamaha bulbs
Discussion in 'Motorbike Technical Discussion' started by pinkpanther, Mar 17, 2006.
  1. pinkpanther
    pinkpanther Guest
    Is there a standard replacement for the Yamaha bulbs (P/N
    42X-83517-00-00), something like an automotive 194 or 168 bulb?
    Thanks Larry
  2. pinkpanther
    pinkpanther Guest
    Has anybody tried LEDs on an older bike? Good, bad, ugly?
    Thanks,
    Larry
    pinkpanther, Mar 24, 2006
  3. pinkpanther
    pinkpanther Guest
    Thanks,
    Larry
  4. pinkpanther
    John Johnson Guest
    LEDs for which lights exactly?
    I am not aware of bespoke LED replacements for indicator or tail/brake
    light housings for any bikes, though I have not looked very hard.
    There are LED "bulb" replacements (a matrix of LEDs with a standard lamp
    socket on the back) available, but I haven't tried them (and have heard
    decidedly mixed reviews).
    I also know that people have wired up custom solutions on various bikes,
    either as accessory/supplementary lighting or as replacements. As custom
    installations, they are by definition not standard.
    fwiw
    Later,
    John
    John Johnson, Mar 25, 2006
  5. pinkpanther
    Don Fearn Guest
    I got an array of LEDs to replace the dim and power-hungry bulb on the
    rear of my Triumph TR6R and I'm pretty pleased. It's bright and uses
    WAY less power than the original; that's a GOOD thing on a motorcycle
    that has a marginal electrical system . . . .
    -Don
    Don Fearn, Mar 25, 2006
  6. I swapped a complete tail light assembly for a 52 LED truck light.
    I like the better visibility and not having to worry about bulb
    failures. I got motivated right after almost getting rear ended when
    my tail light bulb burned out.
    The light I used is about 4" x 6", costs about $25 on eBay
    and is commonly used on delivery trucks.
    To mount it on the bike, I fabricated a bracket to replace the
    tail light and license plate holder. The tail light pops into
    a rubber grommet that in turn pops into a rectangular hole
    in the bracket I made.
    Rob Kleinschmidt, Mar 25, 2006
