Q for K100 owners
Discussion in 'UK Motorcycles' started by Andy Bonwick, Apr 11, 2008.
  1. Andy Bonwick
    decimated means both "to reduce by one tenth", and in more modern
    usage, "almost completely wipe out".
    So you'd be wasting your time.
    darsy, Apr 17, 2008
    #61
  2. Andy Bonwick
    Which bit of "resists" and "needless" were you having trouble with?
    ogden, Apr 17, 2008
    #62
  3. Andy Bonwick
    none of it. I just didn't think it applied to me.
    darsy, Apr 17, 2008
    #63
  4. Andy Bonwick
    SaladDodger Guest
    Well, over that time, I've done both.
    Indeed.
    SaladDodger, Apr 17, 2008
    #64
  5. Andy Bonwick
    We always tell customers we need 110 cfm and the only slugs I know of
    are the ones you kill in the garden.
    Andy Bonwick, Apr 17, 2008
    #65
  6. Andy Bonwick
    crn Guest
    Just take a look around any tyre shop dealing with truck tyres.
    They are the main users of rattle guns and this is the pressure at which
    they are designed to work.
    crn, Apr 17, 2008
    #66
  7. Andy Bonwick
    I said in another post that I know **** all about pumping tyres up so
    I accept that you might have to use 10 bar to do so but I suspect that
    if this is the case then it's because their air receivers are limited
    and the supply lines are no bigger than 1/2" bore.
    It's a pointless argument because you claimed that 10 bar was needed
    to work an impact gun and it simply isn't. I'm working at a power
    station at the moment and you can be certain the fitters are using
    impact guns every day to strip the turbines and the compressor is
    running at 92 ps. How do I know it's 92? I put a gauge on it
    yesterday.
    Andy Bonwick, Apr 18, 2008
    #67
  8. Andy Bonwick
    Big Dave Guest
    Not quite :
    a mole is a unit of substance equal to number of atoms as 12 grams of
    carbon-12 or a small black furry critter
    a slug is a unit of gravitational mass of approximately 32.174 pounds
    or a small slimy thing that you find in your back yard.
    http://phrontistery.info/unit.html
    Big Dave, Apr 18, 2008
    #68
  9. Andy Bonwick
    Eddie Guest
    Mole Problems? Call Avogadro now on 6.02214179x10^23!
    Eddie, Apr 18, 2008
    #69
  10. Andy Bonwick
    Or B&Q.
    platypus, Apr 18, 2008
    #70
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    "Or ye tekkin' de fekkin' piss, or ye? Y're deid, so yer fekkin' or!"
    (tm) Homebase Marketing Department.
    Wicked Uncle Nigel, Apr 18, 2008
    #71
  12. Andy Bonwick
    SD Guest
    .... and it worked! A lot more difficult of course, because of the
    extra weight, but it was attached. I attached the cush drive to enable
    me to rotate the shaft, and at first it made the same clonking noise.
    I was sure the splines hadn't lined up so persevered with the turning
    .... "donk-donk-donk-donk-donk-donk-donk-KER-DONK-silence". Wahey!
    Two small ratchet straps from MachineMart have calmed my nerves a lot.
    So, the swinging-arm is in, properly, the exhaust system is
    reattached, and I'm now onto the crash bars and shiny exhaust covers,
    etc. Tomorrow, the wheel can go in, then rear end plastics can be
    reassembled.
    What fun.
    SD, Apr 19, 2008
    #72
