Putting a spoke in
Discussion in 'UK Motorcycles' started by Pete Fisher, Oct 19, 2008.
  1. Pete Fisher
    Pete Fisher Guest
    Having just returned from the MX practice track with a disconsolate lad
    and a YZ85 with a wobbly back wheel I need to do a crash course in wheel
    truing. Or perhaps I should GAMI.
    My fault really. He is jumping the bike higher each visit as his lap
    times come down, and I should have been checking the spokes in the rear
    wheel more often. As he lubed the chain between sessions he found one
    spoke free of its nipple and several others very loose. He did say he
    heard a twang at one point, but the red mist was in charge.
    The spoke appears to have come free of the nipple rather than break. So
    does the FOAK reckon I can risk replacing the spoke and just truing it
    all up as best I can by eye, or is a trip to Central Wheels or somewhere
    similar advisable.
    It's only a motocrosser (and the bike).
    | Pete Fisher at Home: |
  2. Pete Fisher
    You should be able to do it easily enough. Just mount the spindle in a
    vice, set up a couple of wire prongs that just touch the rim (one on
    the side of the bead & one on the end), & get twiddling. I respoked
    both Tiger's wheels from scratch this way & they haven't fallen apart
    (yet).
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Oct 19, 2008
  3. When I bust a spoke in the 400 Four's rear wheel recently, I just shoved
    a new one in and tightened it up, but the rim wasn't distorted.
    There's plenty of advice and practical stuff on the web about wheel
    building, so just have a go. If it doesn't work, then throw it at a
    builder. Central Wheel is bloody expensive, though: I used Hagon last
    time, or if you're local there might be an old geezer who'll charge
    about £30.
    The Older Gentleman, Oct 19, 2008
  4. Pete Fisher
    Pete Fisher Guest
    Trust you to come up with a DIY solution. Certainly worth a try - ta.
  5. Pete Fisher
    Motoliner sorted out a badly dented spoked rim for me - £65 inc. postage.
    I'm pretty sure they could true a wheel.
    http://www.motoliner.com/
    Maidstone, Kent
    sweller, Oct 19, 2008
  6. Pete Fisher
    Pete Fisher Guest
    In communiqué <1ip2c3n.9rkb178v3hejN%>,
    The spoke that came loose is also, unfortunately, a bit bent. So a new
    one is required. If he was ready for a big wheel conversion and the
    requisite swinging arm didn't cost a bomb I would just get it rebuilt.
    There is a reasonably cheap wire wheel builder in Smethwick if all else
    fails.
    I won't know the worst until we get the wheel out later. The rim looks
    un-dinged, but virtually every nipple is loose.
  7. Pete Fisher
    Eddie Guest
    As others have said, you should be able to DIY.
    If you're replacing a spoke, remember to follow the lacing pattern used
    by other spokes.
    You should aim for all the spokes to have the same tension first (test
    by twanging them and listening), then true the wheel by adjusting the
    tension.
    If *all* the spokes are loose, it's going to be a bit trickier; have you
    got a similar wheel to compare it to, to get some idea of the required
    tension?
    If you're trying to take out a wobble, adjust the spokes near the centre
    of the wobble more, the two or three on either side slightly less,
    IYSWIM. Don't try to do too much at once, it requires patience and a knack.
    You might be able to true it on the bike, if you've got something to
    lift the back wheel and there's sufficient clearance.
    This is for pushbikes, but might have some useful information:
    http://sheldonbrown.com/wheelbuild.html
    Eddie, Oct 19, 2008
  8. Pete Fisher
    If the wheel isn't out of true then just bung a new spoke in. I once
    replaced all the spokes in my YZ's rear wheel by doing it one spoke at
    a time, working across the wheel. As you say, it's only a 'crosser and
    doesn't have to be absolutely true. I did find that the spokes (these
    were stainless straight-pull ones) took bloody ages to bed in and
    needed retightening pretty much every session the first time I took it
    out.
    One other thing: check the rim & hub aren't cracked. The weight being
    taken on a small part of each could have put excessive stress on them.
    Pip Luscher, Oct 19, 2008
  9. Pete Fisher
    Pete Fisher Guest
    As others have said, you should be able to DIY.[/QUOTE]
    Possibly, as we have a typical MX type paddock stand.
    Ta.
    Unlike Krusty, who can probably change a tube in 10 minutes at the side
    of a muddy track like Malcolm Smith, I haven't taken anything other than
    a push bike tyre off for years.
    The tyre had to come off because the errant nipple had disappeared
    inside.
    I swore never to do a tyre change again after struggling with an 18 inch
    Continental on the R90.
    The 14 inch Michelin Starcross was a little bugger, even with the Heyco
    levers that came with said R90.
    Still it's off now and I will read up the theory before proceeding
    tomorrow after much red medicine tonight.
  10. Pete Fisher
    Heh - used to be able to when I was out getting muddy every weekend,
    but I wouldn't even try these days.
    Krusty
  11. Pete Fisher
    Eddie Guest
    You should be fine.
    Many people see it as something of a black art, but take your time, make
    small adjustments, and you should haven't a problem. I like truing
    wheels, it's one of those zen-like tasks.
    Eddie, Oct 20, 2008
  12. Pete Fisher
    Pete Fisher Guest
    You should be fine.
    make small adjustments, and you should haven't a problem. I like truing
    [/QUOTE]
    Having more of an "ah glasshopper" experience so far. A few of the
    nipples are well and truly corroded to the spokes. The perils of MX on a
    track with a surface like mortar mix and concomitant jet washer
    shenanigans I suppose.
    It wouldn't matter too much if they weren't also slightly loose at
    present. It may be that they are only so because the wheel moved
    relative to the hub because of losing two spokes.
    Anyway, luckily I purchased a bumper size can of plusgas at Stafford, so
    the wheel is standing with the rusty nipples uppermost after a liberal
    soaking. I will let it penetrate for a while and see if they will shift.
    Fortunately, I reckon I can mount the wheel back in the bike (without
    brake caliper in position) whilst on the stand and rig up some Krusty
    type wire pointer jobs.
    Given that he will be moving on to a big wheel ASAP so that we can
    source half decent rubber for his hill climb debut in 2010, I think I
    may try and make do with a wheel that I can hopefully get back into at
    least as good a state as it was when we first got it.
    Pete Fisher, Oct 20, 2008
  13. Pete Fisher
    Eddie Guest
    < snip >
    In case you haven't already realised: if you can get the tyre off, and
    they're anything like pushbike nipples, they'll have a screwdriver slot
    at the normally-hidden end.
    This might offer more purchase than the normally-visible part (and is
    what you'd use when initially building a wheel, as it's much quicker to
    tighten all the nipples with a screwdriver than to use a spoke key).
    Eddie, Oct 20, 2008
  14. What he said.
    The Older Gentleman, Oct 20, 2008
  15. Pete Fisher
    Pete Fisher Guest
    < snip >
    [/QUOTE]
    Oh, yes, the tyre had to come off to retrieve one nipple anyway. Most of
    the loose ones have nipped up with a screwdriver, but I don't want to
    chew up the slots.
    I am regularly dosing the stuck nipples from inside the rim with
    plusgas. I'll see how an overnight soak does then resort to a bit of
    localised heat.
  16. Pete Fisher
    Given your recent winnings, why don't you just get Central Wheel or
    Hagon to bung a new set of spokes in the post & cut the old ones.
    You'll save a whole heap of grief, & if you go for mild rather than s/s
    they won't cost much.
    Krusty
    Krusty, Oct 20, 2008
  17. Pete Fisher
    Pete Fisher Guest
    I'll certainly consider it. I could cut the old ones out and replace one
    at a time, as I don't fancy building a wheel from scratch.
  18. Pete Fisher
    Eddie Guest
    *ding*
    *ding*
    *donk* <fx: tightens>
    *ding*
    Eddie, Oct 20, 2008
  19. Pete Fisher
    Ben Guest
    I started building wheels in similar circumstances and then was taught
    properly when I worked in a pushbike shop.
    I've often pondered setting up a small home business building pushbike
    ones.
    If you want a difficult pattern to learn, try a Snowflake...
    http://farm3.static.flickr.com/2156/2035017512_778871d0b7.jpg
    It's a lot of fun calculating the spokes lengths you need for that.
    Ben, Oct 21, 2008
  20. Pete Fisher
    Eddie Guest
    Given how quickly and cheaply our LBS[0] does them, I can't see it being
    profitable.
    I'll bet. Does it serve any practical purpose, or is it just decorative?
    [0] Bicycle Repair Man[1], http://www.bikerepairman.co.uk/
    [1] 306b!
    Eddie, Oct 21, 2008
