Putting a bike in a van
Discussion in 'UK Motorcycles' started by rob2, Sep 8, 2006.
  1. rob2
    rob2 Guest
    What's the best way to get a motorcycle to stay upright and safe in the
    back of a luton van. The vans got a tail lift to the liftings taken
    care of, but i'm clueless as to how to tie it down once inside.
    Its a fazer 600 so has a centerstand if that matters, not sure if the
    van will have a place to tie it to inside as it will be a moving style
    boarded out van. The rest of my belongings will also be in there as I'm
    moving flat. I'm hoping it has the waist height metal tie down points
    that other vans have IIRC, just tie it as best I can through the front
    to each side and the back the same?
    rob2, Sep 8, 2006
  2. rob2
    Always use the sidestand - it makes the bike more stable: it can only
    fall one way, then ;-)
    Run the bike in all the way to the front, before you load anything
    else. Take it up to the front left corner at 45degrees and wedge the
    front tyre against the front wall of the van. Settle it onto the
    sidestand, making sure the front wheel is tight against the wall, and
    put it in first gear.
    All you need is one strap then, off the left pillion peg down to the
    floor across the van to the left. Pull that down a bit and your bike
    won't move, especially when you pack the rest of your stuff around it.
    Pivoting a bike on its sidestand on a raised tail lift is an art form,
    mind.
    Pip, Sep 8, 2006
  3. rob2
    antonye Guest
    One of these:
    http://www.on-bike.com/products_bikegrab.htm
    and then some handlebar straps like these:
    http://www.motrax.co.uk/Index_pages/accessories/hdbarstarps.htm
    You don't even need to secure the Bike Grab to the floor,
    just push the bike in and then use the bar straps to hold
    it in place. We put ours on a paddock stand once in the
    grab, but don't bother strapping the back down.
    antonye, Sep 8, 2006
  4. rob2
    Cane Guest
    Lay the bike down on it's side. Job done.
    Cane, Sep 8, 2006
  5. rob2 wrote
    <*sigh*>
    The bitch drives the van and you ride the bike.
    steve auvache, Sep 8, 2006
  6. Is it worth strapping the front brake lever too?
    Si
    Mungo \Two Sheds\ Toadfoot, Sep 8, 2006
  7. rob2
    Not IME, no.
    Pip, Sep 8, 2006
  8. rob2
    Domenec Guest
    It is when the bike is on a trailer with the front wheel being heavily
    charged so that there is friction between the wheel and the floor.
    Domenec, Sep 8, 2006
  9. rob2
    rob2 Guest
    I can visualise how that'll work out, thankyou.
    Don't see many people pivoting bikes on a sidestand, I assume
    I can practice this once in the road. Might have a go now for fun.
    rob2, Sep 8, 2006
  10. rob2
    Kevin Seal Guest
    Ask the bastards that nicked mine....
    Kevin Seal, Sep 8, 2006
  11. rob2
    Veggie Dave Guest
    Theoretically, anyway. In practice, on the other hand...
    Veggie Dave
    UKRMHRC#2 BOTAFOF#08
    IQ 18 FILMS http://www.iq18films.com
    IQ 18 RADIO http://www.iq18films.co.uk
    Toxic Shock Syndrome Gets More Girls Than Me
    Veggie Dave, Sep 8, 2006
  12. rob2
    MattG Guest
    'snot that tricky. Might be a little tense, like, but it's not that
    hard.
    MattG, Sep 9, 2006
  13. rob2
    Lay it on its side and pile mattresses on top of it.
    platypus, Sep 9, 2006
