Purging Hydraulic Clutch
Discussion in 'Australian Motorcycles' started by Petesin, Jul 28, 2003.
  1. Petesin
    Petesin Guest
    anyone care to right a quick "How To" for purging the line on the hydraulic
    clutch of a VFR? (or any bike i guess)
  2. Petesin
    stef Guest
    same way you bleed the brake lines....
    open bleeder valve, pull clutch, close bleeder, release clutch, repeat until
    it feels right
    using a bleeder hose into a jar of fluid makes life easier as it wont suck
    any air back into the system (available at KMart,etc for < $10)
    stef, Jul 28, 2003
  3. Try this one for a quick and easy fix
    This will work fine as long as you dont have any leaks, if you are going
    through clutch fluid then you have leaks! get it fixed properly.
    If you don't have leaks simply get yourself a cable tie or panduit strap or
    string and pull the clutch lever all the way in and secure it with the cable
    tie or whatever.
    Now leave the bike overnight and with them ports open the air will bleed
    out. Cut the cable tie off and operate the lever a few times and you are
    back on the road again.
    If this does not work then you probably have a leak or blocked ports in the
    clutch master cylinder. Either way you are gonna have to pull things apart,
    clean em up in metho, put it back together and bleed it the old fashoned
    way.
    paul sullivan, Aug 11, 2003
