Puncture Repair
Discussion in 'UK Motorcycles' started by zootius, Apr 2, 2007.
  1. zootius
    zootius Guest
    I'm Cursed. My CBR that tried to kill me in December felt decidedly
    odd when I got it out of the garage last night - steering eratically -
    so I nursed it to the petrol station at the bottom of my hill and
    checked the front tyre pressure. Supposed to be 36psi - was 10psi.
    Jeeeez. Didn't look that underinflated.
    So found a large tack sticking out of the tyre - prized it out -
    hissssss - stuffed it back in again. Balls.
    In the garage they sold a 6 quid SOS Tyre Repair aerosol. After much
    faffing about with the brake discs making manoeuvering the aerosol and
    garage inflator hose a nightmare, and foam flying everywhere turning
    the scene into a tragic comedy snowstorm, I wrestled the tyre back up
    to pressure and got home.
    Testing the pressure again today, it seems the repair has held. But
    does anyone have any experience of using this foam stuff? How long
    will the repair last, and has my use of this foam stuff meant that my
    tyre shop won't be able to do a proper repair later?
  2. zootius
    Boots Guest
    They're usually a get you home / to a tyre shop device. Read whatever
    it says on the stuff. I've tried and had no luck with the foam stuff
    in the past, however, the plugs that can be inserted from outside work
    well enough. Tyre places usually whinge about foam because it has to
    be cleaned out before replacement / proper repair.
    Boots, Apr 2, 2007
  3. zootius
    Moon Badger Guest
    zootius wrote:
    :) BTDTGTTS
    It may last ages, or it may fail immediately. Don't trust it to do anything
    other than get you home at low-ish speeds. I have used it before and
    totally forgotten it was there. I have also used it and barely made it home
    before it failed. YM-W-V
    They may object to it, or even charge you a couple of quid for cleaning it
    out, but it does not damage the tyre, nor does it stop a proper mushroom
    plug being fitted.
    Some places are a bit arsey, some aren't. Ring round first.
    Moon Badger, Apr 2, 2007
  4. Get-you-home only, really.
    No
    The Older Gentleman, Apr 2, 2007
  5. zootius
    Mark Guest
    Lots here will scoff but I've used Ultraseal on a Bandit 1200 and more
    recently on the Blackbird for around 4000 miles including 500 miles on the
    Isle of Man at speeds of around 150 mph. I've never had a problem with it
    and it certainly seals punctures. I originally used it to repair a puncture
    in a 200 mile old rear. The only thing I don't agree with the manufacturers
    is that I never found it improved tyre mileage.
    Just make sure you put in EXACTLY the right amount otherwise you may get a
    bit of an imbalance.
    I wouldn't use any other foam personally.
    Mark
    Mark, Apr 2, 2007
  6. Can I be the first?
