puncture repair
Discussion in 'UK Motorcycles' started by Dan L, Nov 5, 2005.
  1. Dan L
    Beav emerged from their own little world to say
    They looked something up in a book. Nothing fell off as I made my way to
    Newhaven for a TOG Tour and I didn't have a problem getting the wheel out
    when I went to a different tyre fitter later in the year.
    wessie, Nov 5, 2005
  2. Dan L
    Scraggy Guest
    Er, actually centrifugal force throws all gunks outwards, to the inside
    crown(ish) of the tyre. So nothing to clean off IYSWIM
    Scraggy, Nov 6, 2005
  3. Dan L
    BGN Guest
    But when the wheel isn't turning gravitational forces must make the
    gunk higher up fall downwards.
    BGN, Nov 6, 2005
  4. Dan L
    Scraggy Guest
    A, IME, a very small ammount, which is reflung :)
    Generally most remains clinging to the tyre.
  5. Dan L
    On Sat, 5 Nov 2005 21:21:03 -0000, "Beav"
    Having just had a look at my front tyre I don't think it'll survive
    another rear tyre without being dangerously fucked by the time the
    rear has worn out so I'll be firing up ebay and buying a new pair of
    sticky tyres. Probably Rennsports because they always seemed ok when I
    used them on my 9R.
    Andy Bonwick, Nov 6, 2005
  6. Dan L
    MattG Guest
    2 Wheels charged me a tenner, and within a couple of hours the tyre was
    flat again.
    MattG, Nov 6, 2005
  7. Dan L
    MattG emerged from their own little world to say
    I had one year where I seemed to have magnetic tyres. They repaired 3
    puntures[1] with mushroom type patches. It was on my VFR750 so they were ZR
    tyres. All done by the same chap - a short arse ginger bloke. £5 cash each
    time. That was 9 years ago mind.
    It's a shame that place closed as they carried a good stock of tyres and
    did a decent job. Although it would be a bit of a trek now that I don't
    work in the Forest of Dean.
    [1] 2 in the same rear Dunlop which went on to do a 2500 mile trip to the
    Alps.
    wessie, Nov 6, 2005
  8. Dan L
    deadmail Guest
    Ultraseal is fitted by the place that does my tyres (if you pay for it).
    I doubt they'd fit it if it made a mess of the rims.
    It's different from the old foams that set solid (normally into a lump
    at the bottom of the tyre IME).
    deadmail, Nov 6, 2005
  9. Dan L
    someone here Guest
    Gloop
    Goop
    Punctureproofit
    Slime
    Slyme
    Ultraseal
    all variations of a theme. The latest formulations are actually made to be
    removed with water! Too many complaints from tyre companies.
    I have used puntureproofit and ultraseal and had no problems when changing
    tyres.
    YMMV
    someone here, Nov 7, 2005
  10. In uk.rec.motorcycles, someone here amazed us all with this pearl of
    wisdom:
    What happens when you ride in the rain?
    Whinging Courier, Nov 8, 2005
  11. Dan L
    deadmail Guest
    I find it's best if you put the stuff inside the tyre rather than
    outside. YMMV.
    deadmail, Nov 8, 2005
  12. Dan L
    BGN Guest
    Doesn't look as good though, does it?
    BGN, Nov 8, 2005
  13. In uk.rec.motorcycles, BGN amazed us all with this pearl of wisdom:
    You pair of dickheads.
    *obviously* you put the stuff on the inside <ffs>, but the gloop, or
    whatever it's called, has to come out of (or leak out of) the hole a
    biyt for it to plug the hole.
    What happens when you ride in the wet with said gloop in the hole?
  14. Dan L
    BGN Guest
    Let us know.
    BGN, Nov 8, 2005
  15. Dan L
    Scraggy Guest
    You just don't understand how this works do you? It doesn't matter about
    water, cos once you've forked out for the gloop, you never ever, ever get a
    puncture.
    Scraggy, Nov 8, 2005
