puncture repair
Discussion in 'UK Motorcycles' started by Dan L, Nov 5, 2005.
  1. Dan L
    Dan L Guest
    Anyone know of a ride in / ride out puncture repair place within easy
    striking distance of Bicester.
    The zephyr seems to have developed a squashy front tyre.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R (Going)
    Dan L, Nov 5, 2005
  2. In uk.rec.motorcycles, Dan L amazed us all with this pearl of wisdom:
    Nope, but don't you have a kwik-fit type place near there?
    Could be the valve, mate.
    Whinging Courier, Nov 5, 2005
  3. In uk.rec.motorcycles, Dan L amazed us all with this pearl of wisdom:
    Well, IANATF, but a puncture repair's a puncture repair, innit?
    I mean the AA did a front puncture on the CBR (pre-ratted) and it lasted
    the life of the tyre. In fact I did the BOMB run with it in.
  4. Dan L
    Dan L Guest
    do they do bikes then?
    I checked that last time I noticed it was flat, all seemed okay though.
    Dan L (Oldbloke)
    Dan L, Nov 5, 2005
  5. Dan L
    deadmail Guest
    Ultraseal.
    deadmail, Nov 5, 2005
  6. Dan L
    Dan L Guest
    Seriously?
    Dan L (Oldbloke)
    Dan L, Nov 5, 2005
  7. Dan L
    Dan L emerged from their own little world to say
    http://www.superbiketyres.com/branch_location.htm
    Branches in Thame, Abingdon & Witney.
    I've used the Witney branch. They are very professional[1]. I've only had
    tyres fitted - phone them about a punture repair.
    Open until 5pm today and Sunday until noon
    [1] only tyre fitters I've seen use a torque wrench
    wessie, Nov 5, 2005
  8. Dan L
    deadmail Guest
    Yes, if it's a slow puncture. I've used it for exactly this purpose and
    have done many miles using it in tyres- since I've been using it I've
    not had a single puncture. Recommended. I think 'slime' is pretty much
    the same.
  9. Dan L
    Dan L Guest
    Cheers. A trip to Halfords may be in order then.
    Dan L (Oldbloke)
    Dan L, Nov 5, 2005
  10. Dan L
    Scraggy Guest
    Wot he said. I've used Slime for several tears. Does wot it says on the tin.
    Scraggy, Nov 5, 2005
  11. Dan L
    Scraggy Guest
    FFS. Insert 'Y' in place of choice.
  12. Dan L
    I know it's supposed to be ok in sportsbike tyres but I'd be reluctant
    to leave it in the tyre for long whereas I'd quite happily ride flat
    out on a plugged tyre. I've not got a reason for this but that doesn't
    matter in the greater scheme of things.
    I've got a bit of a problem at the moment in that I need to look at
    replacing my rear tyre but I don't need a front one yet. I always like
    to have the same type of tyre back and front but if I was replacing
    both I wouldn't be putting the same type on again. Do I just change
    the rear like for like and wait until the front has worn out before
    changing to something different, do I change both even though the
    front is ok or do I mix them up?
    I was hoping Champ would replace his rear tyre before me so I could
    get some feedback from him but the useless bastard insists on using
    his gixxer and asking me what I'm doing about tyres. I reckon it'll be
    two new tyres fitted over winter when the bike has a rest.
    Andy Bonwick, Nov 5, 2005
  13. Dan L
    Wik Guest
    That bit's true but by the same token, a bike tyre-fitter and a car
    tyre-fitter ain't the same thing. Most car places simply don't have the
    facilities if, indeed, the knowledge and, unsurprisingly, vice-versa.
    Few franchise/chains like Kwik-Fit do both bike and car tyres although
    some of the larger independants do.
    As to Dan, sorry I dunno.
    Wik, Nov 5, 2005
  14. Dan L
    Dan L Guest
    My problem is that it appears that tyre peeps won't repair Z rated tyres,
    and seeing as mine only have a few thousand miles on I am reluctant to bin
    it.
    The puncture seems to be really slow, so I reckon I'll give the goop a go.
    Prolly won't make me popular with mt garage when I do come to change the
    tyre, but there you go.
    Dan L (Oldbloke)
    Dan L, Nov 5, 2005
  15. Dan L
    I've had ZR tyres repaired at 2 places. Five Acres Garage near Coleford and
    the now defunct 2 Wheel Tyres in Gloucester.
    The latter was the best as the service was off the books and generally
    involved a fiver into the fitter's back pocket. Five Acres charged me a
    tenner + VAT.
    As far as the gloop goes it didn't cause a problem when I used it on a GS
    tyre. I used Tyreweld to get me home on a bank holiday Monday. There was
    very little residue on the rim which came off easily.
    wessie, Nov 5, 2005
  16. Dan L
    You're not short of a few bob - change 'em both and fit the type you
    want and stop being such a pikey ****. You can always take the
    part-worn front tyre away with you and move it on or use it to
    necklace a gatso.
    Looking after their own arses. Not repairing Z-rated tyres is
    bollocks. Many places do just that, but some are more concerned about
    possible comebacks than offering decent service to the pikey
    community.
    Anyway, why the **** have you got Z-rated tyres in any case? It's
    only a fucking old Zephyr, so the tyre is hardly going to be subjected
    to gross acceleration forces and continuous high speeds - and you ride
    the thing, so the cornering forces will be pretty minimal. The only
    exceptional factor is the weight of the bastard.
    What you need is a pair of T-rated Cheng Shins with a band of concrete
    compound across the centre inch - last you for ever, they will.
    Goop it. Fitters don't seem to give a shit any more, as the modern
    stuff sticks to the tyre and not the wheel. Make sure you adhere(sic)
    to the instructions about rotating the wheel though.
    Pip, Nov 5, 2005
  17. Dan L
    Dan L Guest
    Heh, I am a proud member.
    The Avons were recommended here, I only realised they were Z rated when I
    checked today.
    Are you trying to say something about my cornering skills? ;)
    Heh, sounds about right for me then.
    Reckon I will, when I can be arsed to find some of the stuff.
    Dan L (Oldbloke)
    Dan L, Nov 5, 2005
  18. Dan L
    deadmail Guest
    Well, I don't think Dan's got a sports bike. My experience over about
    20k miles has been it's fine. Or at least it doesn't make the BMW feel
    any different.
  19. Dan L
    I wish I could afford to just sling tyres away because they don't feel
    right. I know what I want to do and I know what I can afford to do and
    I reckon I'll strike a compromise between the two.
  20. Dan L
    MikeH Guest
    What, buy a new one but not fit it?
    MikeH, Nov 5, 2005
