New or serviced parts need adequate initial lubrication when the engine or power train is first started. The general rule is if it moves, lubricate it. Most mechanics simply use engine oil on parts as they are assembled. This provides an antifriction film until the driven pressure/splash oiling system circulates oil from the sump(s). My theory is passageways are void after a rebuild and it will take a considerable time for oil to circulate to normal flows. New and rebuilt parts are rough and generate considerable friction until they are well broken in. Thes parts need extra lubrication for their protection. I suggest instead of engine oil, grease be substituted. Grease is simply oil suspended in various soaps to keep the oil in place. That is the objective, to keep oil in place until the oil pump can come up to speed. I recommend "pure white" grease sold in any auto parts supply and labeled as such. Liberally coat every part: valve stems, main and rod bearings, wrist pin, rings and piston grooves, gears, and essentially every part which has relative movement with respect to the other. The grease is rapidly absorbed by the oil (engine or gearbox) after it has done its job. Avoid moly grease and other non-pure greases as some contamination of the regular oil is inevitable when those exotics are employed.
