Project Idea - Trike ( I must be feckin' mad)
Discussion in 'UK Motorcycles' started by Donegal Paul, Nov 4, 2003.
  1. Donegal Paul
    Donegal Paul Guest
    "Lozzo" said to Donegal Paul wibbled like a little girl....
    <mental note>don't fucking weld them bars!</mn>
    Donegal Paul, Nov 5, 2003
    #61
  2. Donegal Paul
    Grimly Curmudgeon wibbled like a little girl....
    Dennis from D+G motorcycles has now fitted a 5.7 litre V8 Yank lump into
    his trike, named Goliath. It looks quite impressive.
    Lozzo
    ZZR1100D, GPZ500S, CB250RS x3.
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3, HYPO#1.
    www.mjkleathers.com
    Lozzo, Nov 5, 2003
    #62
  3. Platypus wrote
    Perhaps not.
    steve auvache, Nov 5, 2003
    #63
  4. Another one I saw had only the clutch between engine and axle. NO means
    of putting it into neutral...
    GS 850 x2 / SE 6a
    SbS#6? DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Nov 6, 2003
    #64
  5. Donegal Paul
    I saw what I think was a elderly FZR which had been slightly modified
    by some mad Scot - he'd fitted an RS1600 engine in line, inside the
    frame. There was only one major frame mod, just under the tank, a
    bulge to accommodate the twinchoke downdraught carb.
    That had no gearbox, just a hydraulic clutch and a fuckoffandie
    enormous rear sprocket. He reckoned it was a right hoot to pull away
    from the lights and just wind it on - all the way to 160+ without
    changing gear ;-)
    It prolly is now, as the fake, empty right-hand can was going to take
    a nitrous bottle ...
    Pip, Nov 6, 2003
    #65
  6. Donegal Paul
    Champ wibbled...
    There is if you rip out the back seats, cut all the boot bulkhead and
    panels away and then weld in enough strength to be able to stick another
    front subframe complete with engine/box in there.
    I've seen the photos of the original, and also seen first hand a replica
    that some nutter built around 1990. The replica was much better built
    than John Cooper's version.
    Lozzo
    ZZR1100D, GPZ500S, CBCBCB750RSRSRS
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3.
    www.mjkleathers.com
    Lozzo, Nov 6, 2003
    #66
  7. Donegal Paul
    Perfect for you then!
    Hog, Nov 6, 2003
    #67
  8. Donegal Paul
    Ah, right. That explains it
    Q. How do you get two engines in a mini?
    A. One in the front, one in the back.
    Champ, Nov 6, 2003
    #68
  9. Donegal Paul
    Ben Guest
    Or just put two in the back:
    http://www.zcars.org.uk/mini/mini_twin_rl.htm
    Ben, Nov 6, 2003
    #69
  10. Donegal Paul
    athomik Guest
    Disk brakes are available for Beetles, anything from a cheapo arrangement to
    high-tech race specs, (although a lot of people fit all sorts of set-ups,
    inc. Porsche). And they did come in a semi-auto version. And they don't need
    any water.
    I just wonder if anyone ever tried running a Beetle engine backwards? Then
    you could have a nice air-cooled, mid-engined setup.
    athomik, Nov 6, 2003
    #70
  11. Donegal Paul
    athomik Guest
    Didn't some bloke from Desperate Dan's run a V10(12?) Mercedes trike a few
    years ago?
    #71
  12. Backwards? You don't have to. Just turn the transaxle arse about tit and
    rotate the engine relative to it. Cooling might be a fucker, though.
    As for the 'nice' part of that setup - not with a VW lump.
    An Alfa twincam of some sort. All polished up.
    GS 850 x2 / SE 6a
    #72
  13. Donegal Paul
    athomik Guest
    Current inventory of spare engine dept.:
    VW engines: 2
    Alpha engines : 0
    athomik, Nov 7, 2003
    #73
  14. You bugger.
    Wandering back from a nice Chinese meal last night, and a
    very nice bottle of red, we saw a CG125.[1] And I thought,
    blimey the engine block is *tiny*. And I thought, it would
    be easy to bolt two CGs together, shift the seat and tank
    to the middle, and just use one front end. And, voila,
    the Holiest of Holy Trikes.
    We could even get AndrewR to bless it.
    William Grainger, Nov 7, 2003
    #74
  15. Donegal Paul
    Will, I don't know how to break this too you gently, but the whole
    "CG125s are great" thing is a cruel joke.
    darsy, Nov 7, 2003
    #75
  16. [sniff]
    You'll be telling me that the tooth fairy isn't real
    next!
    #76
  17. Donegal Paul
    athomik Guest
    Do it like the tractor boys and get either 4 decent sized V8s or a couple of
    engines from an old Wessex helicopter.
    #77
  18. Donegal Paul
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Donegal Paul
    You **** right off and leave that to those that may have more need than
    you.
    Nigel Eaton, Nov 9, 2003
    #78
  19. Donegal Paul
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, William Grainger
    OI! Speciesist ****![1]
    It's a fucking hippo, and don't you forget it.
    [1] (tm) Monotreme
    #79
  20. Donegal Paul
    deadmail Guest
    <fx>: esnipe bid set up.
    deadmail, Nov 9, 2003
    #80
