Project Idea - Trike ( I must be feckin' mad)
Discussion in 'UK Motorcycles' started by Donegal Paul, Nov 4, 2003.
  1. Donegal Paul
    Donegal Paul Guest
    "Big Tim" said to Donegal Paul wrote:
    SNIP
    <cowers in corner>
    Donegal Paul, Nov 5, 2003
    #41
  2. Donegal Paul
    Donegal Paul Guest
    Hmmmm a half track lambretta?
    #42
  3. Donegal Paul
    Big Tim Guest
    Potential, much potential I think.
    Big Tim, Nov 5, 2003
    #43
  4. Donegal Paul
    athomik Guest
    Keep meaning to look into triking one of my VW engines, but that'll have to
    wait until I get the Beetle back on the road.
    athomik, Nov 5, 2003
    #44
  5. Donegal Paul
    Donegal Paul Guest
    "athomik" said to "Yoda Of Borg"
    Ah, well, I looked at the VW as they are all in one units, however, unless
    you build quite a longish trike its likely to keep wheelying, fine and fun
    for a couple of times , but not everytime you pop it into second.
    Hence apparently the mini / Alfa Romeo / ford escort layout is better as the
    engines on or just in front of the wheels.
    At least that's what http://www.btinternet.com/~jhpart/bktrikeo.htm says
    #45
  6. And if you get the balance right/wrong[1], they can be wheeling
    all the time, esp. for a rear engined thing...
    [1] depending on point of view...
    William Grainger, Nov 5, 2003
    #46
  7. Donegal Paul
    athomik Guest
    Not if you build it to have 1 forward and 4 reverse gears. ;o)
    #47
  8. William Grainger wrote
    Usual story. When I had time I didn't have the money and when I had the
    money etc., etc. The real clincher is the chronic lack of a garage to
    keep it in while it evolves.
    I still really fancy my mid engined 2.3litre Bedford Diesel idea but it
    will have to wait until I can find a builder I can trust and the cash to
    pay her.
    steve auvache, Nov 5, 2003
    #48
  9. Donegal Paul
    flook Guest
    flook, Nov 5, 2003
    #49
  10. Donegal Paul
    Donegal Paul Guest
    "flook"said to Mick Whittingham Well **** me. That's exactly the lines my original plans were taking me
    before thinking about putting in a car engine.
    Although, a lambretta not a vespa. **** **** ****.
    Right well, I think ill have to go down the mini engined trike route now and
    get the lump concealed under the bodywork so from the outer it looks similar
    to that vespa.
    #50
  11. Just don't get torpedoed.
    GS 850 x2 / SE 6a
    SbS#6? DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Nov 5, 2003
    #51
  12. You do know the VW transaxle will run quite happily arse-about-face,
    don't you? Gives you a mid-engined configuration that you can fit a
    decent engine to. Only slightly difficult bit is the gear linkage, but
    plenty of folk have done it and it works.
    GS 850 x2 / SE 6a
    #52
  13. Only thing you have to watch is the direction of rotation of the bike
    output and the Reliant axle.
    A mate got his XS1100 trike to the rolling under power stage and found
    he'd got 5 reverse gears...
    Fixed, though. Just swivelled the axle round and made up new brackets.
    GS 850 x2 / SE 6a
    #53
  14. Donegal Paul
    Donegal Paul Guest
    "Grimly Curmudgeon" said in reply to "Donegal Paul"
    Didn't know that at all. Mind you there are other advantages that the mini
    configuration has over the beetle, at least as far as I know
    1) Disc brakes on the newer (1984 ish onwards) minis
    2) If I use an auto mini engine, it will be much easier to sort out
    gearstick placement. Afaik beetles never came as autos??
    #54
  15. Donegal Paul
    Mick Whittingham wibbled like a little girl....
    John Cooper did it in 1965 with his Twini[1]. Two 1275 Cooper S motors
    in an outwardly standard Mini Cooper S shell.
    He almost died when he hit the wall on the Kingston bypass, apparently
    one of the arms that locked the steering on the rear subframe[2]
    fractured at high speed and one rar wheel decided to turn at 90 deg. His
    car hit the wall 7 feet up and the gouge is still there today.
    [1] 2300cc twin cam, 4 carbs, 4wd, discs all round. I spoke to Mr Cooper
    himself about it in 1994 and he still rated it as the most exciting car
    he'd ever driven.
    [2] A modified front subframe/engine/box with bars that locked the hubs
    from self steering.
    Lozzo
    ZZR1100D, GPZ500S, CB250RS x3.
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3, HYPO#1.
    www.mjkleathers.com
    Lozzo, Nov 5, 2003
    #55
  16. Donegal Paul
    Donegal Paul Guest
    "Lozzo" replied to Mick Whittingham wibbled like a little girl....
    This is exactly the set up I propose for the rear end of the trike. Mind you
    Ill have to be sure that the hubs are locked well, or perhaps weld them in
    place ....
    #56
  17. Donegal Paul
    Donegal Paul wibbled like a little girl....
    You can't weld them. The hub needs to be able to move up and down with
    the suspension. Welding bars into place would either lock the
    suspension, or snap the bars when the hubs attempt to move up/down.
    You need track-rod ends monted on bars with a large rose joint at the
    other end which are bolted to the subframe at as close to 45 deg as
    possible to the wheel's directional plane.
    Lozzo
    www.mjkleathers.com
    Lozzo, Nov 5, 2003
    #57
  18. Probably far too late to find one in the scrappers now, but the same
    idea occured to me years back using the 1750 Maxi engine/autobox.
    I think VW experimented with some electrically operated autobox, but it
    was a pile of shit.
    GS 850 x2 / SE 6a
    #58
  19. Donegal Paul
    Platypus Guest
    There was a trike in BSH the other year that was built around a Rover V8
    IIRC. As it was a lightweight, solo trike, and the engine had huge
    torque from well down the rev range, the gearbox was dispensed with and
    the propshaft was attached directly to the back of the diff. Yellow it
    was.
    Platypus - Faster Than Champ
    VN800 Drifter, R80RT
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    Platypus, Nov 5, 2003
    #59
  20. I recall seeing one like that at the Bulldog Bash some years back with a
    smallblock Chevy lump coupled direct via clutch and dogbox to the axle.
    Brutal.
    GS 850 x2 / SE 6a
    #60
