Project Idea - Trike ( I must be feckin' mad)
Discussion in 'UK Motorcycles' started by Donegal Paul, Nov 4, 2003.
  1. Donegal Paul wrote
    It is difficult to get good value advice about all this. Fer a start
    there are not that many people to ask and pretty much all of them have a
    unique story to tell.
    About the only firm conclusion that I have come to in my researches is
    that somebody else will have to do the building for me if I ever own a
    trike.
    Sitting not 12 feet away from me as I type and being as this is Sunny
    Essex it is rusting away a bit slower than in other vitamin D poor
    parts of the country.
    steve auvache, Nov 4, 2003
  2. Donegal Paul
    mups Guest
    Your going to need a diff in there somewhere or corners are going to be
    somewhat interesting. I would have thought that attaching a bike shaft
    to a car diff is easier than trying to get a sprocket onto a diff.
    early escorts has 13" wheels IIRC, how small do you want to go?
    mups, Nov 4, 2003
  3. Donegal Paul
    mups wibbled like a little girl....
    12" Fiesta wheels will fit an Escort axle stud pattern.
    HTH.
    Lozzo
    ZZR1100D, GPZ500S, CB250RS x3.
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3, HYPO#1.
    www.mjkleathers.com
    Lozzo, Nov 5, 2003
  4. Thanks for that. Must find some time to resurrect my project.
    GS 850 x2 / SE 6a
    SbS#6? DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Nov 5, 2003
  5. Reliant Robin rear axles are the common choice - most others need to be
    narrowed, but it can be done fairly easily. Propshaft will cost around
    100 - 120 ukp for one to be made up by a firm like RecoProp in Luton.
    I've seen an open-cased car axle with a sprocket bolted onto the crown
    wheel and chain drive running to the bike engine. Worked fine, the diff
    internals were still in place - all that was needed was regular lubing
    and these days a Snotoil would do that job easily enough.
    GS 850 x2 / SE 6a
  6. Donegal Paul
    Donegal Paul Guest
    hmm, I guess I could always use a mini engine and put 10" wheels on the rear
    Keep it low slung? And there will always be spares.
    Donegal Paul, Nov 5, 2003
  7. Donegal Paul
    Grimly Curmudgeon wibbled like a little girl....
    Good choice of wheels for the Reliant axle. It's meant to run 10" Mini
    wheels, but a range of 4 stud 12" and 13" or 14" wheels from most pre-
    metric[1] BMC/Leyland[2] cars will also bolt straight on.
    [1] Almost anything that was produced before 1984/5, later Metro,
    Maestro and Montegos had stupid[3] wheel/tyre sizes.
    [2] And oddly enough, Hillman Imp 12" wheels.
    [3] Actually not that stupid when you think about it, but different to
    everyone else.
    Lozzo
    www.mjkleathers.com
    Lozzo, Nov 5, 2003
  8. Donegal Paul
    Donegal Paul wibbled like a little girl....
    The beauty of the Mini engine/box is it's compactness. Added to the fact
    that it comes on an easily adapted subframe with suspension all bolted
    up and working. You can just build a rear framework around a Mini
    subframe/engine/box/suspension with locking bars to keep the hubs from
    steering.
    Lozzo
    www.mjkleathers.com
    Lozzo, Nov 5, 2003
  9. Donegal Paul
    Donegal Paul Guest
    "Lozzo"replied to Donegal Paul wibbled like a little girl....
    that's what Im thinking. Certainly sounds like a good first trike attempt
    anyway...
  10. Donegal Paul
    Pete M Guest
    Donegal Paul made the world a better place for us by saying..
    Honda Civic VTEC, YKIMS.
    and it'll fit in a mini, so it'll fit in yer trike..
    Pete M.
    Golf Gti (For Sale)
    Alfa Romeo 164 TS.
    Wahey, I'm a proper petrolhead again!"
    Liverpool, Great Britain.
    "you can lead a horse to water, but a pencil must be lead"
    Pete M, Nov 5, 2003
  11. How about two Lambretta engines gear boxes and drive at the back, one
    each wheel.
    It would be different.
    Mick Whittingham, Nov 5, 2003
  12. Donegal Paul
    flashgorman Guest
    <snip>
    How about a car front end and a lambretta rear. It'll keep you drier in the
    rain. Might have to downgrade the brakes though.
    flashgorman, Nov 5, 2003
  13. I think the easiest option is to get a rear engined car, and
    angle grinder that. Second easiest is front engined car, rear
    wheel drive car and angle grinder the drive shaft, and then reweld it
    shorter, like. Then all your diff mechanism bits are easy...
    Otherwise a shaft drive bike like Nigel's yellow whale
    connects to a rear diff without too much hassle. I have
    seen a CX500 trike that does that...
    It's probably possible, but I can't imagine how you'd
    do chain/belt drive sensibly.
    Larger engine = better.
    William Grainger, Nov 5, 2003
  14. What happened to your trike project?
  15. Donegal Paul
    Donegal Paul Guest
    "Mick Whittingham" said
    It would be fecking difficult, especially when it comes to gear changing etc
  16. Shouldn't be if you though about it. There have been several twin
    engined cars built. One of the fastest accelerating at one time was a
    twin engined VW Sirocco.
    It would be different :)
  17. Donegal Paul
    Donegal Paul Guest
    "William Grainger" said to Donegal Paul <>
    wrote:
    SNIP
    Aye, im tending to lean towards a mini at the mo, especially as i used to
    have on years ago and was fairly familiar with the engine etc.
    Ive come to realise that the shaft drive is the better option when it comes
    to using a motorbike engine.
    Now that ive done a little more research :)
    LOL
  18. Donegal Paul
    Donegal Paul Guest
    "Mick Whittingham" said to Donegal Paul
    Stop it right now, stop putting more and more ideas in my head, there's no
    more room :)
  19. Donegal Paul
    Big Tim Guest
    Thing is, you've tapped into a huge supply of supressed energy from
    all the potential trike builders out there in UKRM land and beyond.
    They now have a focus for all their ideas.
    And they won't let you forget this easily.
    Be Afraid, Be Very Afraid...
    Big Tim, Nov 5, 2003
  20. Donegal Paul
    Dr Zoidberg Guest
    Well you wouldn't need to worry about steering , just increase the revs on
    one of the engines and get pushed left or right.
    Dr Zoidberg, Nov 5, 2003
