Project Garage is go
Discussion in 'UK Motorcycles' started by Ben Blaney, Dec 30, 2003.
  1. Should do ok. I'd think the PVA will help it last longer anyway as the
    concrete surface will be sealed.
    GS 850 x2 / SE 6a
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Dec 30, 2003
  2. Ben Blaney
    Ginge Guest
    Skill.
    Mine's one of the newer ones with the 8 cyclone thingies instead of the
    2 - dunno if that makes a difference. I bought it because it had the
    least offensive colour scheme (grey and turqouise) of all the models.
    Ginge, Dec 30, 2003
  3. On Tue, 30 Dec 2003 20:21:45 +0000, Doesnotcompute
    Not if it comes out of a French tap, no.
    GS 850 x2 / SE 6a
  4. Ben Blaney
    Ben Blaney Guest
    Blaney in "reasonable DIY decision" shocker!
  5. Ben Blaney
    Ben Blaney Guest
    Mine too.
    Can't remember the colour of mine. Not unpleasant, I think. But I am
    to colour what Champ is to taste.
  6. Ben Blaney
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Ben Blaney
    Buy a couple of cheap soft brooms.
    Quickest and easiest way to paint a floor known to man.
    Nigel Eaton, Dec 30, 2003
  7. Ben Blaney
    Ben Blaney Guest
    I was going to use a roller and an extension pole, but now you mention
    it...
  8. Ben Blaney
    Nigel Eaton Guest
    That'll work if you've got a very even smooth floor. Otherwise the
    brooms are your friends.
    If you *have* got a very even smooth floor you'll want some grippy stuff
    (like very fine sharp sand) mixed in with the paint to avoid comedy
    banana-skin-stylee routines. Last stuff like that I bought was from a
    yacht chandlers, which means I only overpaid by 200%.
  9. One thing to check first. Throw some water down and make sure the floor
    slopes towards the door. Much easier to sweep up dust with a wet floor,
    and you don't want the garage filling up...
    SimonB - South Wales. BOF#32
    email simonb@zapikdotcodotuk
    Triumph Sprint ST,
    ZXR750L2 Wazimbaki.
    Kawasaki Z1R For Sale
    eric the brave, Dec 30, 2003
  10. Ben Blaney
    The slightest oil or fluid spill will be bloody dangerous on a shiny
    floor.
    Can you just mix into the paint sharp sand, if so how much?
    sweller, Dec 30, 2003
  11. Nigel Eaton wrote
    They do that with indoor cart tracks to give grip so I am told. Special
    type of non toxic to flooring sand they use as well, washed probably.
    steve auvache, Dec 30, 2003
  12. Ben Blaney
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, sweller
    Ho yuss.
    Probably, and **** nose.
    HTH.
  13. Ben Blaney
    My workshop floor is made of absorbent concrete. And is black.
  14. Ben Blaney
    Ben Blaney Guest
    Good thinking. I'll do that.
  15. Ben Blaney
    Ben Blaney Guest
    Cane was telling me about that on the phone earlier. I'm going to do
    one coat, see how it looks, and then lob the sand in to the second or
    third, depending on how the coverage is looking.
  16. Ben Blaney
    antonye Guest
    Well, I've got one empty one atm, which is prime for sorting
    first as a kind of tester. The finish on the floor is typical
    new-build "slop it down and **** off" so I think I may need
    to either skim or put some kind of self-levelling down first,
    depending upon what ThoseThatKnow recommend.
    Then I need to move everything from one t'other and repeat
    the process!
    antonye, Dec 30, 2003
  17. Ben Blaney
    antonye Guest
    You could probably get away with using kiddies play sand
    as that has usually been washed/bleached/cleaned and is
    about 3 quid for a bag, so not too pricey. Try your local
    Early Learning Centre (which is bound to be twice the
    price of everywhere else because it's "Educational" sand
    rather than ordinary sand) or even our Tescos sells it.
  18. Spriknle dose
    er..
    Sprinkle some dry sand on the wet paint. Plenty of it, but not so much
    you get saturation coverage. Let dry and brush off.
    GS 850 x2 / SE 6a
  19. Ben Blaney
    Linger Guest
    Send out invites to the opening!
    Linger, Dec 30, 2003
  20. Ben Blaney
    Statto Guest
    Even Claret and Blue?
    Statto, Dec 30, 2003
