Problems with Honda STX1300 Fuel Injection / Electronics?
Discussion in 'Motorbike Technical Discussion' started by losheng, Jul 12, 2007.
  1. losheng
    losheng Guest
    Hi, Guys,
    While doing some research on the STX1300 with the local mechanics,
    I've learnt that there are many incidences of STX1300 with all kinds
    of electronics related problem. One is the blinking of the FI warning
    light at around 8-90 mph. Others include symptoms that looks like a
    'hang' of the onboard system, which required a reset by disconnection
    and reconnecting the battery terminals.
    Does any of the fellow STX owners has any experience with such
    problems? Or perhaps the local tropical heat has rendered the
    electrical components less reliable?
    Also, does anyone know if it is possible to purchase the factory
    maintenance manual for STX1300?
    Thank you,
    ls
  2. losheng
    Gary Walker Guest
    STX1300? Is that like a ST1300?
    Gary Walker, Jul 12, 2007
  3. losheng
    losheng Guest
    Hey,
    I apologise, I meant the ST1300. :)
    losheng, Jul 13, 2007
  4. losheng
    Bruce Farley Guest
    You should be able to order the Factory Shop Manual at any Honda dealership.
    Bruce Farley, Jul 13, 2007
  5. After a little googling
    There seems to be a Honda 1300 recall for a bad (marginal) ground
    in the wiring harness. Bad grounds can certainly cause many, many
    kinds of electronic weirdnesses.
    http://www.ownersite.com/RecallMain.cfm?action=models&make=HONDA
    Rob Kleinschmidt, Jul 14, 2007
