Price differences
Discussion in 'UK Motorcycles' started by dwb, Jul 13, 2004.
  1. dwb
    Daz Guest
    Price tends to vary a bit but only by about £10. He reckons he sells
    them to racers at trade but I'm sure he makes a few quid. Just make
    sure you tell them you race if you use them.
    Daz, Jul 14, 2004
  2. dwb
    Daz Guest
    Oh bollox. The whole reason for my reply was to give the number...
    01274 532777 ask for nigel
    Daz, Jul 14, 2004
  3. dwb
    dwb Guest
    Cuntybollox wrote:
    It might surprise you to know I can do these.
    I, however, draw the line at removing wheels.
    The chain issue is the alignment/tension - not HOW to do it. i seem to get
    one or both wrong (too tight looks right to me) and as a result chain loses
    it's o-rings.
    Therefore I know my limits and now don't do it.
    Changing a fuse != whipping a wheel out without the bike falling over.
    dwb, Jul 14, 2004
  4. dwb
    If you're ever in Brighton, apart from look me up anyway, I'll show you
    how to adjust a chain /without/ fucking it up and what the proper tension
    looks like.
    Loose is the short answer.
    sweller, Jul 14, 2004
  5. dwb
    dwb Guest
    Because I don't have the equipment to do a good job. I wouldn't be
    comfortable doing a bodge as I value my bike in it's current state and see
    no reason to find new and exciting ways to break the plastics on it for the
    sake of it.
    Also, removing the wheel would serve no purpose as that doesn't help me
    change the tyre.
    dwb, Jul 14, 2004
  6. dwb
    Verdigris Guest
    I've never removed a front wheel, and only done a rear wheel once on my
    own. I wouldn't even have bothered with that time if I'd had a realistic
    alternative. Before then I'd have had to say that I didn't know how to
    remove the rear wheel, but it didn't exactly worry me.
    Verdigris, Jul 14, 2004
  7. dwb
    dwb Guest
    *sigh* Yes and no.
    I'm focussing on the tyre changing because that is what matters to me.
    I see your point about gaining experience because it would serve me well in
    the long run. Don't disagree, but TBH, I don't have the inclination, time or
    need to practice removing the wheels on my bike, or dismantling.
    There you go.
    dwb, Jul 14, 2004
  8. dwb
    Verdigris Guest
    Just to be clear, I was entirely confident that I could take the rear
    wheel out, with assistance[1] from the Book of Lies. It's just spanners
    and stuff, and a bit of brute force.[2] I expect the front'd be the same.
    [1] Actually, not a lot of assistance and it seemed to be trying to make
    it harder work, without actually telling you how the **** to get the thing
    lined up to get the axle in again, which was the only difficult bit, so I
    largely ignored it.
    [2] Quite a lot, actually. I expect that means I did it wrong and it'll
    all fall apart on the motorway one day.
  9. dwb
    Ben Blaney Guest
    Cuntybollox wrote:
    I just lay down in bed and it happens.
    Ben Blaney, Jul 15, 2004
  10. dwb
    dwb Guest
    Simple instructions eh? Yes the instructions are very simple. Just not very
    useful.
    Getting the adjusters to line up - not quite so simple, or rather very
    simple when the main nut is loose - but then they both move when it's done
    up - thus changing the alignment and the tension of the chain.
    Then there is the question of the slack - the GSX-R manual actually says
    20-30mm - but it shows it in BOTH directions - ie up and down combined -
    which is what I did - and that was, obviously, way too tight.
    So in a phrase, **** off with your condescension.
    What number engine are you on now?
    Maybe on your bike changing the tyre pressure is like adjusting the chain -
    it isn't on mine.
    What is with this "I'm so manly, I can do stuff to my bike" approach? FFS -
    just because you're so gung-ho that you can single-handedly **** up your
    bike, sorry 'undertake servicing and repairs', why does that mean I should
    feel the slightest bit inclined to the do same - especially when it costs
    virtually nothing as part of a service.
    You make your choice, I make mine.
    dwb, Jul 15, 2004
  11. dwb
    Verdigris Guest
    Of late, I just sit down in front of the telly and it happens.
    Then I wake up at 5 am. :-(
    Verdigris, Jul 15, 2004
  12. dwb
    Eddie Guest
    You lucky bastard.
    Eddie, Jul 15, 2004
  13. dwb
    Ben Blaney Guest
    I've always been a good sleeper. I get to sleep within about a minute
    of getting into bed. I never wake up in the night: I sleep until my
    alarm goes off, or I've had enough sleep. Job done.
    Ben Blaney, Jul 16, 2004
  14. dwb
    Ginge Guest
    You're very lucky.
    I tend to lie awake for in excess of an hour with my mind churning
    things over, I frequently wake tired around 5AM, still needing more
    sleep.
    Ginge, Jul 16, 2004
  15. dwb
    Ben Blaney Guest
    I know. You know what else - apart from, and despite being overweight
    - my BP is bang on normal, my cholesterol is fine, and I'm /never/
    ill; so I reckon I'm really fucking healthy.
    Probably drop dead next week.
    Poor ****.
  16. Now - you still have youth on your side. Take it from someone who has
    been complacent and whose health is now not all it could be. While you
    can make those small but sensible adjustments to trim the weight a bit
    and exercise a bit more. Nothing huge but just make it a habit now so
    you don't face the fear and hassle of much bigger adjustments later in
    life.
    Doubtful but there's no need to shorten your expectancy either.
    Paul Corfield, Jul 16, 2004
  17. dwb
    Ben Blaney Guest
    No I don't. I'm old.
  18. dwb
    Ben Blaney Guest
    Oh, I have plenty of stress, I assure you. It's just that it doesn't
    affect my sleep; nothing does.
    Ben Blaney, Jul 17, 2004
  19. You're younger than me...
    William Grainger, Jul 19, 2004
  20. dwb
    Ben Blaney Guest
    With considerably fewer significant achievements. Jeez, that makes me
    feel even worse.
    Ben Blaney, Jul 19, 2004
