Power valve.
Discussion in 'Classic Motorbikes' started by taz, Jul 2, 2004.
  1. taz
    taz Guest
    Can anyone explain how the power valve works?
    Cheers taz.
    taz, Jul 2, 2004
  2. It's a valve. It's controls the power.
    Simon Atkinson, Jul 3, 2004
  3. taz
    riccip Guest
    Modern power valves work like a shutter to adjust the height of a
    stroker's exhaust port. At low revs they prevent power erosion by
    restricting the premature exhaust of unburned fuel/air. When the
    revs increase they open to allow better breathing giving optimum
    power. The effect is to give a wider useful power band across the
    rev range but they don't actually increase the engine's BHP.
    Before power valves you needed to rev the guts out of a stroker
    to make it fly. Anyone who's owned a Yammie RD400 will know the
    lethal kick when the rest of the horses come charging in at 6000
    rpm. Consequently they've all been "up the road" at one time or
    another with an undented example difficult to find. Not that this
    ruined the machine as taming the beast was part of it's appeal.
    The YPVS system that followed worked using a servo motor to turn
    a spool-shaped port valve thus constantly retuning the exhaust
    port. It offered much improved flexibilty but the design appeared
    to ignore the heat and clag generated under hard thrashing making
    them sticky and unreliable bastards to maintain.
    riccip
    riccip, Jul 3, 2004
  4. taz
    I'd have thought it was slow speed work that causes gumming up.
    Thrashing them would generate enough heat to keep them clean.
    I've never had YPVS but I've had a number of two strokes.
    sweller, Jul 3, 2004
  5. Broadly, you can shape the ports of a two-stroke to give decent
    mid-range and torque and not much top end, *or* sod-all mid-range and
    torque and a screaming top end.
    MZ is a classic example of the former, and an old Kawasaki H1 of the
    latter.
    If you wanted a fast two-stroke, you had to make do with the engine
    deficiencies elsewhere in the rev range.
    What a power-valve does is adjust the port height by means of a
    revolving barrel at the edge of the port. So you can have a screaming
    top end *and* decent mid-range.
    It doesn't actually increase power by itself, as you say. It just makes
    the bike more driveable.
    Control is via a servo motor, yes, and a sensor system which monitors
    engine revs etc.
    However, power-valves used to seize up if the bike was driven too
    *slowly*, because in a two-stroke that's when you get unburned crap
    gumming things up.
    Also, on the 350, the power-valves were right at the front of the block
    (well, they had to be) and the bike's inadequate mudguarding allowed all
    sorts of road crap to splatter onto them, which didn't do them much
    good. On the TZR250 and RD500LC they were better shielded, and gave much
    less trouble.
    The Older Gentleman, Jul 3, 2004
  6. taz
    taz Guest
    Cheers guys.
    Do the manufacturers use a similar type of
    system or do they vary from make to make?
    Whilst looking for bikes that are for sale I have
    seen once or twice a reference to the power
    valve being disconnected. Are some of
    them a manual thing?
    Cheers taz.
    taz, Jul 3, 2004
  7. taz
    Ian Guest
    KTM use a simple centrifugal device with ball bearings running up a track
    against springs in their 2 stroke competition off road machines. I spent
    many a happy hour cleaning the clag off the valves on my last one.
    Ian
    Ian, Jul 3, 2004
  8. That's because Yamaha still hold all the patents on their own system
    which was, and remains, the best.
  9. They vary. As I've said elsewhere in this thread, Yamaha invented it and
    the Yamaha system remains the best. Suzuki's RGV250 used a sort of
    guillotine affair, IOIRC, and Kawasaki and Honda had their own versions.
    None is a manual system AFAIK, though you can convert Yamaha ones to
    manual via a handlebar lever instead of a servo motor. Hardly an ideal
    solution, though.
  10. taz
    The Older Gentleman was seen penning the following ode to ... whatever:
    That's the one that occasionally guillotined its engine, right?
    Timo Geusch, Jul 3, 2004
  11. You've owned one, then?
  12. taz
    Even I'm not that mental. Occasionally tempted by the Aprillia RS250,
    but I've managed to resist so far.
  13. taz
    riccip Guest
    You're right. It's arriving at slow traffic in town while they're
    still hot that gets the PV seals hissing like a Madagascan
    cockroach which is why they're a nasty commuter.
    Maybe I was unlucky but mine was a bitch. Terrible build quality,
    ropey electrics, and it would routinely seize then unseize on the
    motorway with no apparent reason (or damage). Strictly for solo
    scratching as an anorexic on the pillion would turn the headlamp
    into an anti-aircraft searchlight. The earlier LC's (4L1) were a
    much better bike provided you looked after the cooling system.
    But the old aircoolers are still by far the best IMHO. A pair of
    Allspeeds and an induction kit can beef up the mid-range power
    almost as good as powervalves, and god they can take some thrape.
    riccip
    riccip, Jul 4, 2004
  14. Same engine, so same chance of the infamous piston hitting the valve
    problem that some later RGVs had.
    mike. buckley, Jul 5, 2004
  15. taz
    mike. buckley was seen penning the following ode to ... whatever:
    I know that. Which is why, curiously enough, I managed to resist the
    temptation so far.
    Timo Geusch, Jul 5, 2004
  16. taz
    ITYF that most MXers use mechanical power valves 'coz there's sod-all
    of an electrical system.
    Pip Luscher, Jul 5, 2004
