I've had a few times the battery has been dead with the CBF500, if left standing for over 4-5 days after a full charge. The battery was probably 3-4 years old and I don't know if this is a standard shelf life for a bike battery. Anyway, I've swapped the battery but did a few additional tests at the time. Leakage when the ignition was of, 10mA from the heated grips. At 2,000RPM I get 14.2V across the battery terminals, 5,000RPM 13.7V and it drops a little more with more revs (red line at 10k, so I seldom get about 7-8k anyway). 5,000RPM should be 14-15.5V according to Haynes. Did a test on the three yellow cables from the alternator coil to the rectifier, all came out at 0.7 ohms. Within spec according to Haynes. So I swapped the rectifier, but got the same results at 5,000RPM. Anything to do with the alternator isn't going to be cheap. Any other suggestions as I've already spent £60 on a rectifier. Is this going to cause any issues for the new battery i.e. significantly shorter life span? I've noticed my heated grips are great between 2,000-3,000 RPM and almost off (through winter gloves) at 5,000 RPM. So I'm not sure how much current is getting through. My guess is a battery needs 1-4A to charge and the grips 2A. Tim B
