possible Calais->Chimay route sans Autoroutes
Discussion in 'UK Motorcycles' started by darsyx, Jul 11, 2005.
  1. darsyx
    darsyx Guest
    From Calais:
    N43 to Bethune
    D937 to Aras
    D939 / D43 through Cambrai
    N43 through Le Cateau-Cambresis to Hirson
    D1050 / N99 to Chimay
    About 165 miles, none on motorways. Guestimate 3.5 hours?
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    Horrible bit of road, loads of poxy little villages with speed limits,
    ped X-ings and that kind of crap. I'd (personally) use the autoroute for
    this bit just to get it over with.
    and Ducati Race Engineer.
    Enfield 500 Curry House Racer "The Basmati Rice Burner",
    Wicked Uncle Nigel, Jul 11, 2005
  3. darsyx
    darsyx Guest
    that does sound grim. I really hate autoroutes though, and prefer not
    to use them unless I need to get a lot of miles covered in a day - in
    this case, it's just a 160 mile early morning bimble - don't really
    want to get to Chimay much before lunchtime anyway (start from Calais
    is about 8:30am).
    I'll have a bit of another look at the map.
    Are you actually going to this thing, BTW?
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    Nope, but I remember the N43 with displeasure from the last couple of
    Frog trips.
  5. darsyx
    I've a funny feeling the N43 was the road we ended up on for a while a
    few years back on a TogTour when Sniper had a fucking puncture[1]. Like
    I said, I'll reconsult my newly purchased "France & Benelux" map and
    have another think.
    [1] I still to this day wish I'd just fucked off and let him get on
    with it.
    darsy, Jul 11, 2005
  6. darsyx
    zymurgy Guest
    Well, that's hardly the spirit is it ?
    Ah, it was Sniper, as you were then :)
    Cheers
    Paul.
    zymurgy, Jul 11, 2005
  7. darsyx
    it was more the fact that - as I learned after we'd stopped[1] - he'd
    noticed that his rear tyre looked a bit flat before he'd even got on
    the boat in Dover.
    [1] had I know this before leaving Calais, I wouldn't have ridden in a
    group with him in it, IYSWIM.
    darsy, Jul 11, 2005
  8. darsyx
    Salad Dodger Guest
    If you were on the way to Caudebec or Duclair, I hope not.
    | ___ Salad Dodger
    _/_____\_ GL1500SE-V/CBR1100XX-X/CBX1000Z
    |_\_____/_| ..75939.../...19198.../..30340.
    (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4
    |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11
    \|^|/ ANORAK#17 IbB#4 PM#5 WG*
    '^' RBR Clues: 24 Pts: 400 Miles: 1589
    Salad Dodger, Jul 11, 2005
  9. darsyx
    Salad Dodger Guest
    Suggestion by Mapsource: 148 miles - no Autoroute.
    N43 to Saint-Omer,
    D933 to Hazebrouck,
    D944 to Baillieul,
    D933 to Lille,
    D941 to Tournai,
    N7 to Barry,
    N50 to Mons,
    N40 to Beaumont,
    N53 to Chimay.
    | ___ Salad Dodger
  10. darsyx
    "something".
    darsy, Jul 11, 2005
  11. darsyx
    Salad Dodger Guest
    Go East for three hours, then look at the map.
    | ___ Salad Dodger
  12. darsyx
    Whatever. I'll go along with whatever route you come up with.
    ...and on this evening's Guzzi related progress [1] it better be a slow
    one with plenty of two stroke supplies en route.
    [1] New fork springs and damper units lift the forks enough to stretch
    the brake hoses I fitted to the old shaggged front end.
    It gets better. I. Sincerely. Hope.
    sweller, Jul 12, 2005
  13. darsyx
    **** that shit. Take the A26 out of Calais. It's piss-easy to find, gets
    you out of town and gives you a good start on racking up the miles.
    Flat-stick for 30-odd miles to Jn 4 (you'll run into a bit of péage, but
    whatever), go into a little town called Thérouanne, then SE on the D341
    through Houdain to Arras.
    4+
    platypus, Jul 12, 2005
  14. darsyx
    that's OK with me, not sure about Fatman and Bobbin.
    well, with MZ-boi, probably.
    darsy, Jul 12, 2005
  15. darsyx
    He's been down that route a couple of times, so he'll probably be leading.
  16. darsyx
    I did a bit of work on the Guzzi yesterday. Fitted the swishy new fork
    internals and discovered the original springs were well and truly
    nadgered: under length and sagging impressively compared to the new two
    piece stock.
    So impressive are they that the front end has come up an inch or so.
    Which is enough to cause one of the brake lines to be stretched at full
    lock.
    Hilarious.
  17. darsyx
    Salad Dodger Guest
    Drop the yokes.
    Simple.
    | ___ Salad Dodger
    Salad Dodger, Jul 12, 2005
  18. darsyx
    Assuming you mean drop the forks through the yokes, this is not that
    simple as the Guzzi is an absolute **** to shift the stanchions. I
    rebuilt the forks with them in situ as it's quicker.
    Using wedges on the yoke clamps doesn't seem to make much difference [1]
    except to make it look like one's cracking.
    However, lowering them had crossed my mind and I may give it a go. How
    much of an effect do you think it'll have on the steering geometry?
    [1] Actually it makes a huge difference but they're still an
    utter, utter ****.
  19. darsyx
    Salad Dodger Guest
    I appreciate that's what it's called, but that's not what actually
    happens, is it? It's all t'other way which.
    Some.
    hth
    | ___ Salad Dodger
  20. darsyx
    arse. Wish I read it properly.
    Hooray for scientific calculations! I will be trying it this evening,
    time permitting.
    <fx: Guzzi breakers put on high alert for T3 yokes>
