possible bike electrics problem?
Discussion in 'Australian Motorcycles' started by Robbie Vidler, Jul 28, 2004.
  1. Hi,
    Yesterday my bike decided that i was indicating to much and put a stop
    to it.
    every single light in the bike blew, Head lights, tail lights (stop and
    tail) indicators (possibly something else)
    there seems to be like a burn capisitor (something else maybe) smell under
    the seat but i cannot pinpoint where.
    the bike also seems to run on what seems to be Less cylinders or something
    similar. like starving for fuel. after the revs pick up,
    which brings me on to another point, the taco is not working either.
    i check a small fuse box (approximately 4 - 5 fuses none of them are
    blown.... something that says digital ignitor i took this out and it does
    not appear to smell funny (couldn't open it up without breaking it)
    bike is an FZR600 1991 model
    located in melbourne
    is there a few things i can try before taking it to a professional... and if
    i do take it to a professional is there such thing as a bike auto
    electrician or do you just take it to a bike shop (so far i've had good work
    performed at Pro Moto, so if i cannot fix it myself i will go there)
    thanks
    Robbie
  2. every single light in the bike blew, Head lights, tail lights (stop and
    yer regyoolator has had the richard
    fulliautomatix, Jul 28, 2004
  3. Robbie Vidler
    Dave Mojo67 Guest
    Have to agree with Paul on this one, but I'll give you the laymans version
    of what happened so you have at least some understanding when the bike shop
    tries to talk shit.
    There is only one thing that causes bulbs to blow, the voltage regulator,
    and on the Fizzers the stock regulators are shit. The voltage regulator
    takes the 90+ AC volts from your alternator (the actual voltage varies, but
    my Fizzer had an unregulated voltage around 90) and converts it to a usable
    voltage for your 12V DC electrical system.
    Regulators blow regularly on old Fizzers, I went through 3 before buying a
    bigger after market one which worked a treat. When they blow they usually go
    open circuit, which means no power goes through it and eventually you'll
    drain your battery. The other thing that can happen is it goes short
    circuit, which means the raw alternator voltage goes through your system.
    12VDC bulbs don't like 90VAC.
    You need to have the regulator replaced by someone who knows what they're
    doing, and then replace the bulbs and check the wiring harnesses for damage.
    If there is any burnt insulation it can short against the frame sooner or
    later, and you'll be stuck one night on the freeway. Take it to the bike
    shop, you'll have to eventually. Whatever you decide, DO NOT buy a standard
    FZR regulator from a wreckers. Learned all this by painful experience a few
    months back. Ymmv, best of luck.
    Cheers
    Dave (Mojo67)
    FZR600 >> ZX6R >> ??? Brisbane
    http://users.bigpond.net.au/mojo67/mojo67.htm
    I used to never be able to finish anything but now I
    Dave Mojo67, Jul 28, 2004
  4. ok that makes perfect sense because the battery has also been going flat
    sometimes and charging up others.
    bike shop it is... but it really helped to understand the problem, and i
    will take it to a bike shop.
    thanks again for the help, at least now i can go in there and say fix this,
    rather then, what is wrong with it (which = screw me over)
    Robbie Vidler, Jul 29, 2004
