Popping on overrun
Discussion in 'UK Motorcycles' started by BGN, Mar 19, 2006.
  1. BGN
    BGN Guest
    Hello sweethearts.
    Mr. ER-5 is starting to develop a 'popping' noise when I go down hard
    on the overrun which it never used to do.
    My general riding style is high revving (especially when I've gone out
    to play) so I do use the overrun to slow down and have done for well
    over 10,000 miles. I few months ago on the way back home I heard some
    gentle popping while I was on the overrun on the way back up my road
    and it did it regularly today while slowing down after bouncing it off
    the rev limiter while on a 50 mile hoon.
    It's due for a service in about 2,500 miles (before the French run in
    late May) and from what I've read here over the last year the general
    suggestion is adjusting the valve clearances(?) which I assume is what
    needs to be done with the ER-5 when it hits the 25,000 mile service.
    Does that sound like a reasonable assumption and is it likely to be
    expensive as I'll mention it as part of the service. Should I get it
    done now, or should I wait for a couple of thousand miles to pass?
    BGN, Mar 19, 2006
  2. BGN
    BGN Guest
    The exhaust has been fucked for ages. Tweets like a canary which I
    understand is a feature of the ER-5.
    BGN, Mar 19, 2006
  3. BGN
    BGN emerged from their own little world to say
    could be the valves; might also be a leaky exhaust allowing air into the
    system so that the unburnt fuel from the overrun detonates. Check for
    corrosion or a loose joint in the system.
    wessie, Mar 19, 2006
  4. BGN
    An exhaust leak is much, much more likely than valve clearances. Needs
    sorting as it can **** up the mixture.
    sweller, Mar 19, 2006
  5. BGN expressed precisely :
    Exhaust leak.
    Harry Bloomfield, Mar 19, 2006
  6. Get used to it - love it, cherish it, want it.
    Dnc
    B1200 - +30bhp ~|~ ZZR1100 - faster when upright
    V2300 - flat cap and rug ~|~ A6 2.5TDi V6 Quattro Sport
    DoetNietComputeren, Mar 19, 2006
  7. BGN
    BGN Guest
    Isn't the exhaust supposed to leak?
    BGN, Mar 19, 2006
  8. BGN laid this down on his screen :
    Only at the far end :)
    A leak mid way allows air to be drawn in which can trigger the unburn
    mixture to burn, hence the popping noise.
  9. In uk.rec.motorcycles, Harry Bloomfield belched forth and ejected the
    following:
    Sounds good imho.
    I'd leave it.
    Whinging Courier, Mar 19, 2006
  10. BGN
    mb Guest
    Cover the noise up by doing lots of KSBs.
    mb, Mar 19, 2006
  11. BGN
    BGN Guest
    I've never done one.
    BGN, Mar 20, 2006
  12. In uk.rec.motorcycles, BGN belched forth and ejected the following:
    You should.
    It's very irresponsible but it's good fun.
    Whinging Courier, Mar 20, 2006
  13. BGN
    BGN Guest
    Is there a speed that this should be done at? If, later on day, I
    find a clear piece of straight road and I'm doing 40mph I just leave
    the clutch alone and throttle open as normal, flick the kill switch
    off for a second and then flick it on leaving the throttle open it
    should do it?
    BGN, Mar 20, 2006
  14. In uk.rec.motorcycles, BGN belched forth and ejected the following:
    Not speed so much as revs. Make sure you're engine is revving enough so
    that when you flick the switch back on, you've got enough grunt to get
    you back up and running again.
    This is how to do it (or rather, how I do it)
    Rev the engine anything between 5,000rpm and the redline, shut the
    throttle and flick the kill-switch, when the revs die down to somewhere
    slower, flick the switch back on again.
    *Bang* :eek:)
    When you've done a few, you'll get a feel of how and when it can be
    done.
