pop, squirt, dribble. (er5 bits)
Discussion in 'UK Motorcycles' started by cat, Apr 28, 2008.
  1. cat
    Post corrected
    Lozzo
    Suzuki SV650S K5
    Honda CBR600 FW trackbike
    Yamaha SR250 Spazz-Trakka
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Apr 29, 2008
  2. cat
    cat Guest
    The radiator is on order.
    This service manual says I should run the engine with the filler cap off
    till the bubbles stop appearing.... necessitating removal of the fuel
    tank. That's an arse... Also, the section on "removal of fuel tank" talks
    about pulling the hoses off the fuel tap in really quite short order.
    I'm a bit confused about the concept of removing the tank and *then*
    running the engine, am I supposed to have a whole workshop with a useful
    header tank to use for short runs?
    Should I hand this over to a greasy man to do, or is the refill of
    coolant not as much as a strife as this manual implies? On the car I've
    always just lobbed a ton of liquid in the top end. (mind you, that's
    broken)
    cat, Apr 29, 2008
  3. cat
    stick Guest
    I'm on about your inability to read a question. Are you in sales? You should
    be if you're not. The poor girl(1) is asking a question about saving money
    not spending what she can't afford.
    (1) It's also obvious that you're trying to grease your way into her
    knickers.
    stick, Apr 29, 2008
  4. cat
    Cane Guest
    Surely advising her that buying a radiator from a breakers is a false
    economy and suggesting that the pattern parts from mad4bikes is, in
    the long term, a better solution is a good answer to the question.
    What would you advise Cat to do?
    Cane, Apr 29, 2008
  5. cat
    Cane Guest
    eww...
    Cane, Apr 29, 2008
  6. cat
    I read the question, I understood exactly what the 'poor girl' is after
    and suggested a suitable solution. Rads from broken bikes are rarely
    any good and often not much cheaper than a new pattern replacement.
    If you had any experience of rebuilding damaged motorcycles properly,
    which I have lots of, you'd have typed the same post as I did.
    For the record, Im one of the best salesmen you're ever likely to come
    across, but I'm good because I'm honest.
    Trolling ****
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Apr 29, 2008
  7. cat
    Colin Irvine Guest
    This is you trying to be helpful, isn't it.
    Colin Irvine, Apr 29, 2008
  8. cat
    I do my best, yes.
    _______
    Ace, Apr 29, 2008
  9. Ask BGN if he's still got one.
    Whinging Courier, Apr 29, 2008
  10. What's up? I've not been following the news. I can guess but it wouldn't
    be the first time I'd done a ****-up
