Poor idling on a 125 Virago
Discussion in 'UK Motorcycles' started by Tosspot, Jul 9, 2008.
  1. Tosspot
    Tosspot Guest
    Starts ok, but once warmed up tends to stall when pulling up at traffic
    lights. Anyone know what I should be looking at?
  2. Tosspot
    A new bike.
    CT, Jul 9, 2008
  3. Tosspot
    Eddie Guest
    Choke? Does it operate correctly?
    Dragging clutch? Does it still stall if it's clicked into neutral before
    coming to a stop?
    Incorrect idle adjustment? After stalling, does it restart and tick-over
    as expected?
    Eddie, Jul 9, 2008
  4. 3 to 4 hopefully, but they might let you out after 2 for good behaviour.
    Brownz @ Work, Jul 9, 2008
  5. Tosspot
    Tosspot Guest
    Well, you get the prize for most humorous response, if not actually most
    helpful!
  6. Tosspot
    Tosspot Guest
    Seems to.
    Nope, that seems to be ok, at least once it's warm.
    Yep. I'll probably just up the idle speed to cover the problem up. Not
    my bike btw for all you smart alecs.
  7. Tosspot
    Sean_Q_ Guest
    Gunk in the idle jet?
    My solution is to pull the carb, remove every brass insert in sight
    and blow compressed air through every opening.
    ps are the innards of the gas tank rusty?
    SQ
    Sean_Q_, Jul 9, 2008
  8. Tosspot
    Tosspot Guest
    Hmmm, bike had stood for around a year, tank got topped up then taken
    down to reserve. Might be the only way to go, but I hate taking carbs
    apart :(
