Plugging tyres
Discussion in 'UK Motorcycles' started by Kiran, Apr 18, 2005.
  1. Kiran
    Kiran Guest
    Feck - Got a small nail in the back 014, and it's only 500miles old.
    Local independent (ex Suzuki) mechanic said he'd repair it and it'd be
    perfectly safe. He's not seen it mind, but it's only a small nail, bang
    in the centre of the tyre.
    Opinions?
    Ta
    Kiran
    Kiran, Apr 18, 2005
  2. Kiran
    I've had punctures in rear tyres plugged loads of times, what's your
    problem?
    darsy, Apr 18, 2005
  3. Kiran
    AndyW Guest
    No problems. Nails in the side walls are much more serious. If it's
    just gone in more or less straight, it'll be perfectly fixable, nothing
    to worry about.
    AndyW, Apr 18, 2005
  4. Kiran
    simonk Guest
    Bang (haha!) in the middle is OK, I think - it's when the repair is towards
    the edge of the tyre that things get a bit dodgy
    simonk, Apr 18, 2005
  5. Kiran
    That is my understanding of the situation.
    Pip, Apr 18, 2005
  6. Kiran
    Ben Guest
    Plug it. The 010 on mine was plugged at around the same distance and
    it's been happily tested to see if Suzuki were lying about the speed
    or not.
    Ben, Apr 18, 2005
  7. Kiran
    No problem.
    Champ, Apr 18, 2005
  8. In uk.rec.motorcycles, Kiran amazed us all with this pearl of wisdom:
    Opinions on what?
    Get it fixed you wussy.
    Whinging Courier, Apr 18, 2005
  9. In uk.rec.motorcycles, Bear amazed us all with this pearl of wisdom:
    Then why's he even asking about plugging it? If he's minted then there's
    no excuse for not getting a new one.
    <Thinks>
    Maybe there's an angle on suing the Highways agency for having a lump of
    gravel in the wrong place because it caused a nail to flick into his
    tyre or something ;)
  10. Kiran
    flash Guest
    Read the FAQ FFS, you're not allowed to plug stuff on here.
    flash, Apr 18, 2005
  11. Kiran
    Kiran Guest
    Thanks for all the feedback. I'll just get it plugged. The only thing I
    was concerned about was the speed rating of the plugged tyre, but it
    doesn't seem to bother anyone here so I'm sure it's fine.
    Cheers
    Kiran
    Kiran, Apr 18, 2005
  12. Kiran
    dwb Guest
    I think the manufac's say you shouldn't plug a Z-rated tyre, but it probably
    doesn't make a difference in the real world.
    dwb, Apr 18, 2005
  13. Kiran
    darsyx Guest
    there's something you don't see every day - a SimonK post about bikes
    that appears to be technically correct ;-)
    darsyx, Apr 18, 2005
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique, Kiran
    No, the prospect of your tyre letting go at high speed doesn't bother us
    at all.
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Apr 18, 2005
  15. Kiran wrote
    It is your tyre, why should we give a shit?
    steve auvache, Apr 18, 2005
  16. The tyre might be VR-rated, but you're only S-rated, so what's the
    problem?
    The Older Gentleman, Apr 18, 2005
  17. Kiran
    Kiran Guest
    Ba-dooom tish. I was waiting for that one. ...
    Kiran, Apr 18, 2005
