Plug Question
Discussion in 'UK Motorcycles' started by AndyH, Nov 7, 2003.
  1. AndyH
    AndyH Guest
    Spark plugs on the GSX1100F keep fouling on short journeys, even when
    I let the bike warm up. It doesn't appear to be as bad if I use LRP.
    Boss suggested using hotter plugs, so I looked into it. Now, most
    sites say I should use the JR9B, but on www.suzukicycles.org it says
    that *UK* model should use the JR10B, with other models using the
    JR9B's. Why is this?
    Would using a JR10B make much difference?
    AndyH, Nov 7, 2003
  2. AndyH
    Wik Guest
    Wet fouling, presumably...?
    Does it /have/ JR9Bs at the moment?
    The advice given makes little sense... I always understood that the lower the number, the
    hotter the plug...
    {googles}
    Mmm, check this out:
    http://www.ngksparkplugs.com/techinfo/spark_plugs/partnumberkey.pdf
    and then, this:
    http://www.ngksparkplugs.com/techinfo/spark_plugs/overviewp2.asp?nav=31000&country=#
    Granted, it's the US site (the Japanese "English" one is rubbish) and they
    do confirm that, for the US anyway, the JR9B is the one to use.
    Therefore, the recommendation to use the /colder/ JR10B doesn't stack up...
    | Wik -UKRMHRC#10- 2000 ZX12R-A1 -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12
    |# You don't believe me | "Experience is the worst teacher.
    |That the scenery | It always gives the test first
    |Could be a cold-blooded killer. | and the instruction afterward."
    ***** human response from wik at blueyonder dot co dot uk *****
    Wik, Nov 7, 2003
  3. AndyH
    AndyH Guest
    Sorry, got it wrong in my head[1], its the 10's I have, should I
    replace with 9's?
    [1] I'm doing 5 projects at the moment and the Boss just gave me
    another one [2]
    [2] The lack of beer doesn't help either (7 days and counting)
    AndyH, Nov 7, 2003
  4. AndyH
    Wik Guest
    In which case, I refer sir to my previous remark.
    Wik, Nov 7, 2003
