Please help: Taking apart fairing
Discussion in 'Australian Motorcycles' started by James Harvey, Jul 3, 2005.
  1. James Harvey
    James Harvey Guest
  2. James Harvey
    IK Guest
    Pinch the protruding conical bit, either by hand from both sides, or, as
    is more likely, if there isn't enough room to get fingers in there, use
    a flatblade screwdriver to do it one side at a time, then wiggle the
    panels apart.
    Alternately, are you sure they don't just pull apart?
    IK, Jul 3, 2005
  3. James Harvey
    J5 Guest
    thats just a rubber grommet and the panel has the spigot that just fits
    through the
    centre of the grommet ,
    just pull on the panel and it will pop back out of the grommet
    be gentle but firm they are just a press fit
    if you have trouble a bit of wd40 as a bit of lubricant will help
    J5, Jul 3, 2005
  4. James Harvey
    James Harvey Guest
    Thank you both for your quick replies!
  5. James Harvey
    James Harvey Guest
    Eh?? Is this an insult to Shell fuel, my intelligence, or both? :)
  6. James Harvey
    Theo Bekkers Guest
    Theo Bekkers, Jul 4, 2005
  7. James Harvey
    John Guest
    No James, Optimax is more than just a fuel ;p
    Johno
    Who is Conehead?
    John, Jul 4, 2005
