Pinting Givi hard luggage - is it possible?
Discussion in 'UK Motorcycles' started by Dave H., Aug 26, 2007.
  1. Dave H.
    Dave H. Guest
    I've seen a set of Givi luggage going cheap, but it's been painted a
    horrible peeling-off-in-scabs bright blue, is there any paint that won't
    peel straight off the plastic? I'd quite like to try colour-matching to Sir
    Nigel (the Kwak metallic grey from '97) as they might look a bit more in
    keeping with the bike.
    Any recommendations? I thought of Plastikote,as that shits like stick to a
    blanket, anything better out on the shelves?
    Dave H.
    (The engineer formerly known as Homeless)
    "Rules are for the obedience of fools, and the guidance of wise men" -
    Douglas Bader
  2. Dave H.
    Dave Emerson Guest
    Givi used (at least) two different plastics with very different finishes.
    One is designed to be painted while the other has a grained surface and that
    slightly greasy touch that is difficult to get paint to stick well.
    Dave Emerson, Aug 26, 2007
  3. Dave H.
    Beav Guest
    First of all, remove all the old paint then clean with alcohol (panel wipe)
    and prime with (ta-daaaaa) plastic primer. This is usually clear, unlike
    your normal grey or tintable primer, and it doesn't need much. It's
    available in aerosols and one aero will (should) be enough for a whole
    luggage set. (panniers and top box)
    Plastikote is actually fucking crap when it comes to sticking to bare
    plastics. Get a good plastic primer, spray on, leave for half an hour, then
    spray normal grey primer over it. Choose colour, paint, lacquer and you're
    done.
    Is Nigel's "Kwak Raw Titanium" btw, or any of the "matte" colours? If so,
    it's a straight metallic paint, but a flat lacquer, so you'll need to mix
    the flatting agent and the lacquer to the correct ratio.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 27, 2007
  4. Dave H.
    Domènec Guest
    Silly dagospeaker question: "primer in aerosol" means it comes in a can, no
    need for a compressor painting gun, etc?
    Tintable primers do come in aerosol cans too? Me understands not.
    Thanks.
    Domènec, Aug 28, 2007
  5. Dave H.
    Beav Guest
    Pre-coloured primers do but tintable ones need to be "made" at the point of
    sale usually. Some paint suppliers sell tintable primers, but unfortunately
    most don't.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 28, 2007
  6. Dave H.
    Domènec Guest
    Ok, will try locally. Thanks.
    Domènec, Aug 29, 2007
  7. Dave H.
    Beav Guest
    Tha's welcome mon.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 29, 2007
  8. Dave H.
    Domènec Guest
    <tries to remember what was drunk prior to think "I'll read this group in
    order to improve my English">
  9. English as wot she is spoke.
    Phil.
    Phil Launchbury, Aug 29, 2007
  10. Dave H.
    Domènec Guest
    Pablito Carmichael, q'ha disho ehte tio, pisha?
  11. Dave H.
    Beav Guest
    ;-) Indeed.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 29, 2007
