Pinging the K100 owners....
Discussion in 'UK Motorcycles' started by Brownz \(Mobile\), Dec 22, 2008.
  1. A'noon all,
    Varying places suggest 35-40 psi front and 39-45 psi rear.
    Anyone got a tried and tested ideal ?
    Sir is travelling solo, but as you know is not waif like in appearence.
    Still fitted with the ever so wonderful Michelin Macadams.
  2. Brownz \(Mobile\)
    Back when I could still be bothered, I used the method of setting the
    pressures to what I thought was right, then going for a good run and
    checking the hot pressures at the end. If the increase in pressure was more
    than 10%, then the starting pressure was low, if it was less than 10%, then
    the starting pressure was high. Adjust and repeat. Whether a 10% increase
    in pressure through tyre heating is the ideal is another question entirely.
    platypus, Dec 22, 2008
  3. Brownz \(Mobile\)
    Front 2.25 bar, rear 2.50 bar solo
    Front 2.50 bar, rear 2.90 bar two up/luggage
    Hog, Dec 22, 2008
  4. Brownz \(Mobile\)
    TOG@Toil Guest
    Manual footnote says add 50% for Brownz.
    TOG@Toil, Dec 22, 2008
  5. Watch it Kate Moss .... I've got my eye on you....
  6. As long as it's not your foot.
    The Older Gentleman, Dec 22, 2008
