Ping them what knows Bandits and their chains
Discussion in 'UK Motorcycles' started by Catman, Mar 14, 2007.
  1. Catman
    Catman Guest
    Chain adjustment looks pretty simple
    Centre Stand
    Undo two large axle nuts
    wind allen bolts until suitable tightness achieved
    Re-tighten axle nuts
    Check for straight
    Anything I'm missing, and what sort of tension is recommended?
    TIA
    Suzuki Bandit 600
    #Triumph Speed Triple: Black with extra black bits (I live in hope)
    www.cuore-sportivo.co.uk
  2. Catman
    Catman says...
    Youve got it right so far. You don't have to undo the axle nut by that
    much because the adjustment is difficult to do if it's too loose. The
    chain tightens by quite a lot as you do the axle nut back up.
    I go for about 2 inches of slack with the bike on the stand. When I wind
    the adjuster bolts I do each one an identical amount of turns inwards to
    keep the wheel alignment the same.
    Lozzo, Mar 14, 2007
  3. Catman
    peter Guest
    The Nordwset is a pain for the chain tightening like that. I find
    wedging a suitable large socket between the lower chain run and the
    swinging arm while I tighten up the axle nut helps.
    peter, Mar 14, 2007
  4. Catman
    Catman Guest
    Hmmm, it's probably not that loose then although it could be a smidge
    tighter. Odd 'grinding' type feeling (not noise, at least not audible)
    from pegs while accelerating. New chain and sprockets possibly, or
    something else I have to worry about?
    TIA
    Suzuki Bandit 600
  5. Catman
    Catman Guest
    Ta. It's been a while since I needed to adjust a chain. Well over 3
    years at least.
    Suzuki Bandit 600
  6. Catman
    Catman says...
    It might be overtight, check it again with someone about your weight
    sitting on the bike. You want about 1 1/2 inches of slack with someone
    on board. Lube the chain as well.
    Lozzo, Mar 14, 2007
  7. Catman
    Catman Guest
    Cheers
    <fx:looks around a office full of fat sods>
    Perhaps if they sit gently :)
    Suzuki Bandit 600
  8. Catman
    Ian White Guest
    Sounds like it's the same as mine (Suzuki GSX750F), except I only have
    to undo one nut to loosen the axle.
    For alignment, the graduated markings on each side should suffice.
    Recommended tension? Not too tight, not too loose. I generally set
    mine to about 3-4 cm of up/down on the bottom middle of the chain,
    whilst it's on the centre stand. This is probably on the tight side
    but loosens up a bit once it's back on the ground.
    Use a torque wrench to avoid over tightening the axle bolt.
    Ian White, Mar 14, 2007
  9. Catman
    Eh? That's impossible, unless GSXs have got some sort of ultra-weird
    swingarm geometry going on.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Mar 14, 2007
  10. Catman
    Beav Guest
    You need to ride that bike more.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 14, 2007
  11. Catman
    *ding*
    the only thing I'd add is that when I was measuring the amount of
    slack, I'd also do so moving the wheel round to check for tight spots.
    darsy, Mar 14, 2007
  12. Catman
    Beav Guest
    I called into a bike shop the other day and the guy was changing the clutch
    plates on his Hinda magna. After slipping the plates in the basket, he
    bolted the end plate on loosely and then headed off for the torque wrench.
    "So what's the torque setting" I asked him. "About 50 lbs/ft" he said. I
    questioned that as it seemed a "bit" excessive, but he knew best evn though
    he obviously hadn't RTFM. He bent down to add the final tightness and I half
    closed my eyes..
    I said "Just tight enough to strip the threads, then back off 1/4 of a turn"
    He yanked down on the first bolt and snapped the moulding off the inside of
    the basket. Job fucked.
    What's the fucking point of using a torque wrench if you don't know the
    proper setting? Because it looks "professional" of course.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 14, 2007
  13. Catman
    Ian White Guest
    Tough crowd today ...
    "Use a [properly adjusted] torque wrench ... "
  14. Catman
    Ian White Guest
    I might be missing your point here, but ...
    Swingarm pivot is behind the front sprocket. If the swingarm's
    hanging, it shortens the rear sprocket -> front sprocket distance. Not
    by a lot, but enough. The chain's looser with both wheels on the
    ground than when on the centrestand.
    SWK's will be along in a minute to tell us we're both wrong. ;)
  15. Catman
    Catman Guest
    No I need to get rid of that bike and go back to one with a proper
    lubrication system :)
    Suzuki Bandit 600
  16. Catman
    Err... so you're saying that when the sprockets are closest together
    (wheel hanging), the chain's tighter than when the sprockets are
    further apart (wheels on ground)?
    Or are you saying that on your bike the end of the swingarm is higher
    than the pivot point when the wheels are on the ground? That's the only
    way the chain could be looser with both wheels on the ground, but that
    would be...well...weird.
    Krusty
  17. Catman
    Ian White Guest
    <fx: Looks at wheels, swingarm assembly and chain, re-reads post>
    Yeah you're right. My bad. I should have stopped at "3-4 cm of play
    when it's on the centrestand".
  18. Catman
    Ian White says...
    You need about 50mm at least of play when the bike is on the centre
    stand
    Lozzo, Mar 14, 2007
  19. Catman
    SD Guest
    Especially if sir has a Blackbird. I was surprised by how much it
    changed from sidestand to just held vertical. On the centrestand it
    needs about three feet of slack.
    | ___ Salad Dodger
    |_\_____/_| ..88045../..23727.../..31893.
    SD, Mar 14, 2007
  20. Catman
    Catman Guest
    You might qualify for the position, though :)
    C
    Suzuki Bandit 600
