Ping Sweller
Discussion in 'UK Motorcycles' started by SteveH, Apr 6, 2006.
  1. SteveH
    SteveH Guest
    I'm making plans to revive the MZ, namely, throwing a new lump into it.
    Is there any difference in the carb jetting between the ETZ 250 and
    ETZ300? - I've possibly got a 250 lump to sling in, but it's a bare
    engine without the carb.
    Cheers,
    SteveH, Apr 6, 2006
  2. SteveH
    SteveH said...
    What happened to the 300 lump?
    Lozzo, Apr 6, 2006
  3. SteveH
    SteveH Guest
    I was a TC and left it idling on the drive, welding the big end bearing
    to the crank.
    SteveH, Apr 6, 2006
  4. SteveH
    Pip, Apr 6, 2006
  5. SteveH
    SteveH Guest
    Yes, yes, we covered this last summer when it happened.
    SteveH, Apr 6, 2006
  6. SteveH
    That's why I wasn't saying anything. If anything, it was pointed at
    Loz, who obviously can't remember. Again.
    You're so fucking sensitive, Steve. You need a reality check.
    Pip, Apr 6, 2006
  7. SteveH
    JackH Guest
    So why didn't you reply to him then, if that was the case?
    Not on this occasion, methinks.
    If anything, you're the one over-reacting...
    JackH, Apr 6, 2006
  8. SteveH
    From the factory book (of which you should have a copy on the disk I gave
    you)
    ETZ 250
    Carb: BVF 30 N 2-5
    (the key number is 30 - compare it to the cast and stamped numbers on
    your carb)
    Main Jet 135
    Pri. Jet 45
    Start Jet 110
    Needle valve 20
    air screw 1 turn out
    Needle 2 A 531 (C 6) with 5 notches
    Needle pos. 3rd from top
    The only real diffeences will probably be main and primary jets.
    sweller, Apr 6, 2006
