Ping Champ
Discussion in 'UK Motorcycles' started by Lozzo, May 25, 2005.
  1. Lozzo
    Did you get my email yesterday?
    Lozzo, May 25, 2005
  2. Lozzo
    Yes. Was waiting to double check the manual before replying.
    However, I'm 99% sure there's no difference in the clutch between the
    R and RR models. Both have three thicknesses of steel plate available
    - by using various thicknesses, you set up the height of the clutch
    stack to be within a certain range.
    It was me being clever with this before Brands Hatch that caused our
    problems. The stock ZX7R has a slipper clutch fitted, but the
    standard set up doesn't allow enough movement in the clutch stack for
    it to properly activate on the overrun. According to the race kit
    manual (and as advised by Slick Bass), you put a couple of thinner
    steel plates in - this allows the clutch stack to ride up the ramps in
    the clutch sub-hub and disengage on the over-run. However, for some
    reason which I've not yet worked out, it slipped immediately unde
    drive. Putting the original steels back in didn't fix it, and while a
    new set of friction plates made it work for a while, there's obviously
    something else going on.
    Champ, May 25, 2005
