It's just a shite page - all answers yield 95%, although the descriptive results vary. -- _______ ..'_/_|_\_'. Ace (brucedotrogers a.t rochedotcom) \`\ | /`/ GSX-R1000K3 (slightly broken, currently missing) `\\ | //' BOTAFOT#3, SbS#2, UKRMMA#13, DFV#8, SKA#2, IBB#10 `\|/` `
Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear Oooh... I sat down this afternoon[1] to watch "Walker, Texas Ranger". Somehow, my day is no longer complete without watching Chuck Norris kick a baddie in the head. Only, this episode featured baddies from Northern Ireland. Well, Northern Iowa, at least. The accents were so bad I had to switch off before anyone even got roundhouse-kicked! I should write and complain. [1] During my "working from home lunch-break", obviously. -- Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in Performance Bikes and Fast Bikes WS* GHPOTHUF#24 APOSTLE#14 DLC#1 COFF#20 BOTAFOT#150 HYPO#0(KoTL) IbW#41 SBS#39 OMF#6 Enfield 500 Curry House Racer "The Basmati Rice Burner", Honda GL1000K2 (On its hols) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big" Suzuki TS250 "The Africa Single" Yamaha Vmax Honda ST1100 wiv trailer
And this is very true in Tech support - the Americans seem to take the view of "I can't do it because I'm not trained in it" whereas most of the British techies I've worked with have the "I sort of know so lets try it and make it up as we go along" mentality. I vastly prefer the second - except when the person doing it actually has *no* idea what they are doing and doesn't have the ability or skill to get away with it. People like that don't seem to last long in support (thankfully) except in the NHS.. Phil
Sounds like my first unix/network sysadmin job - I'd played with iit enough to sound convincing and learnt very quickly on the job. Phil
As an aside have you listened to the more Prog end of metal? People like Ayreon or Dream Theater (their last one Octavarium is very good) have the metal feeling but in more interesting way. Also recommended would be Jordan Rudess (now plays with Dream Theater) and Riverside. On the less metal side of things White Willow is worth listening to (last 2 CDs anyway - sort of a dark Scandanavian metal meets Goth meets Prog). Phil
I've done the same for many of my jobs and contracts. Minus the 'working like a bastard' bit, of course. What's that about, eh? -- _______ ..'_/_|_\_'. Ace (brucedotrogers a.t rochedotcom) \`\ | /`/ GSX-R1000K3 (slightly broken, currently missing) `\\ | //' BOTAFOT#3, SbS#2, UKRMMA#13, DFV#8, SKA#2, IBB#10 `\|/` `
Thing is, the expression "The Older Gentleman" had been around for years, for example in Huckleberry Finn, and was then much used by Terry Wogan, before 'our' TOG plagiarised it for his posting name. -- _______ ..'_/_|_\_'. Ace (brucedotrogers a.t rochedotcom) \`\ | /`/ GSX-R1000K3 (slightly broken, currently missing) `\\ | //' BOTAFOT#3, SbS#2, UKRMMA#13, DFV#8, SKA#2, IBB#10 `\|/` `
Is that the same as "Engaged brain for a couple of hours"? IME it rarely takes much longer than that before one knows more about the subject than does the client. -- _______ ..'_/_|_\_'. Ace (brucedotrogers a.t rochedotcom) \`\ | /`/ GSX-R1000K3 (slightly broken, currently missing) `\\ | //' BOTAFOT#3, SbS#2, UKRMMA#13, DFV#8, SKA#2, IBB#10 `\|/` `
"The builder of the aircraft, however, elected to place the valve back behind the pilot's left shoulder. He did so with the best of intentions. By placing the valve behind the pilot's compartment, on the other side of the back firewall, with only a long rod leading to the handle behind the pilot's left shoulder, he avoided running the gas lines through the passenger compartment, eliminating any possibility of a gasline rupture occuring inside the compartment. He did so, however, at a terrible cost to the human interface, because the only way to switch tanks was to let go of the controls, twist your head to the left to look behind you, reach over your left shoulder with your right hand, find the valve, and turn it. As the National Transportation Safety Board (NTSB) discovered, it was difficult to do this without bracing yourself with your right foot by pressing the right rudder pedal all the way to the floor. And that's what killed John Denver." "The valve: The builder not only placed the valve in a non-standard location, he also rotated it in such a way that turning the valve to the right turned on the left fuel tank. This ensured that a pilot unfamiliar with the aircraft, upon hearing the engine begin missing and spotting in his mirror that the left fuel tank was empty, would attempt to rotate the fuel valve to the right, away from the full tank, guaranteeing his destruction." What a stupid **** of a builder. Really, it defies description that someone should be so bereft of common sense as to do that.
I know someone who was so shit scared in the middle of an oil rig evacuation that he had to be removed from the co-pilots seat in one of the choppers. This was about 30 minutes after another work colleague of mine had fucked up with a gas plug and filled the rig with explosive gasses and about 30 seconds after the deck plates started banging because of the explosions in some of the compartments. The guy who caused the initial problem still complains because he had to go back to the platform and try to fix the problem before they had another Piper Alpha.
