Petrolcan's Z400 engine damage list
Discussion in 'UK Motorcycles' started by Lozzo, Oct 1, 2003.
  1. Lozzo
    It's not as bad as it could have been.
    Before we set off from Aylesbury on the BOTAFOT on Sunday, PC had
    mentioned he had a bit of a rattle coming from the motor, and put it
    down to a dodgy camchain tensioner adjuster. He rode the bike along the
    A413 and A422 for about 25 miles before it slowed down drastically and
    then stopped, then it wouldn't start.
    After PC got the bike to PixieCentral in the 'window-licking-good'
    Transit we took the rocker cover off to find some errant parts swimming
    around in the head. It was very apparent that the right inlet valve
    tappet adjuster had wound its locknut off and then the adjuster itself
    had made a bid for freedom. That would explain the rattle. After this
    had happened, it's my guess that the rocker on its own was smacking down
    on the valve cap at a funny angle and caused the collets to pop out and
    the valve to drop. Luckily the valve collets were still up top along
    with the adjuster screw and locknut. It was obvious that the inlet valve
    was bent, cos it wasn't going either up or down, so the decision was
    made to remove the head and survey the damage caused deeper down. The
    head came off tonight in about 1/2 an hour, and what a lovely bike it is
    to work on. Everything is accessible, and comes apart with the minimum
    of fuss, it's almost like working on a much newer bike.
    Ater a swift but gentle tap on the valve stem ensuring its removal, it
    turns out that as well as the valve being bent, it's broken the base off
    the valve guide. There is also what looks like a crack up the length of
    it, so that's going to need replacement as well. The piston itself has
    only lightly kissed the valve, and shows just a little marking that will
    polish out, but the combustion chamber has some pock marks in it where
    the valve guide remnants have been smacked into it when the piston was
    at TDC. I will be able to get those out using a hand tool of my
    manufacture, similar to a scraping tool. I've done this enough times on
    RD heads that have had broken rings jammed into them.
    All I need now is to find someone to press a new guide in, I can get the
    old one out easily enough.
    So that's the score:
    A top-end gasket set
    A valve guide
    An Inlet valve
    A pair of collets
    Some remedial work on the combustion chamber
    Job's a good 'un
    Lozzo
    ZZR1100D, GPZ500S, CB250RS
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBv#3.
    www.mjkleathers.com
    Lozzo, Oct 1, 2003
  2. IIRC he mentioned this *weeks* ago.......
    The Older Gentleman, Oct 2, 2003
  3. Lozzo
    petrolcan Guest
    I did. I had put it down to the camchain needing tensioning and you
    posted instructions on how to do it. I followed these instructions
    and that seemed to sort it.
    On the morning of the 'FOT, I pointed out to Loz that the rattle had
    returned and I suggested that the camchain tensioner was sticking.
    Loz said that he would show me how to unstick it after the run, the
    rest is history.
    Ultimately the reason the bike broke down is due to me not checking
    the simple things first.
    petrolcan, Oct 2, 2003
  4. Lozzo
    petrolcan Guest
    Bad form etc.
    I've phoned z-power and they have all the bits except the inlet valve
    which is listed as 'no longer available'. They gave me the number of
    Cradley Kawasaki and the end result is the same :-(
    Anyone know where I can source an inlet valve for an '81 Z400 G1?
  5. Erk. It's a fully manual tensioner, so it never, ever sticks, not like
    the modern Kawasaki ones.
    Oh well, you live and learn.
  6. Lozzo
    The Older Gentleman had a fit and wibbled.....
    I wasn't aware of this beforehand. I am now i've stripped the top-end
    down.
    Every day's a school-day
    Lozzo
    ZZR1100D, GPZ500S, various CB250RSs
    www.mjkleathers.com
    Lozzo, Oct 2, 2003
  7. Lozzo
    petrolcan Guest
    We are going to have to settle for a complete head instead :)
  8. Lozzo
    petrolcan had a fit and wibbled.....
    Lets hope not, otherwise the collets and guide you ordered will be
    surplus to requirements
    Lozzo
    www.mjkleathers.com
    Lozzo, Oct 2, 2003
  9. Lozzo
    Irishman receives Spic head job.
    Film on the 11th ...
    Pip, Oct 3, 2003
  10. Lozzo
    petrolcan Guest
    Well, I got a head from an '80 model on it's way. The surplus bits
    will be sent back to Z-Power.
    petrolcan, Oct 3, 2003
  11. Lozzo
    petrolcan Guest
    With any luck it'll touch down tomorrow morning.
  12. Lozzo
    Should be back on the road on Wednesday evening then
    Lozzo
    www.mjkleathers.com
    Lozzo, Oct 3, 2003
