Perth Mechanic help?
Discussion in 'Australian Motorcycles' started by Slartibartfast, Oct 12, 2003.
  1. Well I've put a deposit on a 94 CBR1000 from a dealer in Perth. But I
    remember bugger all about checking motorcyle's. Does anybody know a
    mechanic or some organisiation I can pay to mechanically check the bike for
    meor should I just do it afterwards and get in done under warranty?
    Thanx in advance.
  2. Slartibartfast said....
    Sl> Well I've put a deposit on a 94 CBR1000 from a dealer in Perth. But I
    Sl> remember bugger all about checking motorcyle's. Does anybody know a
    Sl> mechanic or some organisiation I can pay to mechanically check the bike
    Sl> for meor should I just do it afterwards and get in done under warranty?
    Does WA have statutory warranties for used motorcycles that are out of
    factory warranty? If so, it must be about the only state that it does.
    If you know anyone who is qualified to check it out, do it that way,
    before you hand over the readies.
    Only thing to look for is cam chain noise, although I believe that this
    particular problem was fixed on the 1992 and later models.
    Martin Taylor, Oct 13, 2003
  3. Slartibartfast
    Tony tonym Guest
    Speaking from experience I can tell you that Honda fixed their cam chain
    problems only when they used gear driven cams in the VFR :)
    go tiges :)
    tony
    (on his 5th consecutive Honda)
    ** Frisbeetarianism: The belief that when you die, your soul
    goes up on the roof and gets stuck. **
    Tony tonym, Oct 13, 2003
  4. "Tony" tonym@NOSPAMTHANKS_pobox.com said....
    Ohh. Don't let Hatzoloh know. He could hit you with his hahahahonda
    hoodoo.....
    Martin Taylor, Oct 14, 2003
