Personal Reg Numbers
Discussion in 'UK Motorcycles' started by Ash@Work, Sep 12, 2003.
  1. Ash@Work
    Ash@Work Guest
    I'm about to buy a personal reg of somebody that has it 'on retention'.
    What's the proceedure? Is it just a piece of paper similar to a V5 that he
    signs to say I'm now the owner?
    Ash ([:])
    BOTAFOT#82 UKRMFBC#8 HMC#5 YFC#0(KotL)
    ETV1000 Caponord http://www.theredline.co.uk/ballistic
    "If everything seems under control, you're just not going fast enough." --
    Mario Andretti
  2. Ash@Work
    Ash@Work Guest
    F4 STR THN B34R
    Ash ([:])
    Mario Andretti
  3. Ash@Work
    simonk Guest
    J1 OEY
    D38 CON
    simonk, Sep 12, 2003
  4. Ash@Work
    CR45HER
    darsy, Sep 12, 2003
  5. Ash@Work
    Alan.T.Gower Guest
    N1 CE
    Alan.T.Gower, Sep 12, 2003
  6. Ash@Work
    flashgorman Guest
    You need the JustABitSad form from the post office. I think you also have to
    sign away your personal good taste allowance as well.
    flashgorman, Sep 12, 2003
  7. Ash@Work
    flashgorman Guest
    OK TH3N
  8. Ash@Work
    I regularly see a Jeep Wrangler with "B16UNS". Female driver, natch...
    darsy, Sep 12, 2003
  9. Has she?
    William Grainger, Sep 12, 2003
  10. Ash@Work
    yes.
    darsy, Sep 12, 2003
  11. Good. Nothing worse than false advertising.
  12. Ash@Work
    flashgorman Guest
  13. Ash@Work
    Ginge Guest
    I know someone who used to own 'THE 911' on a lovely old example of the
    correct car.
    Ginge, Sep 12, 2003
  14. Ash@Work
    flashgorman Guest
    Discussion at work the other day about whether Joey Deacon was electrocuted
    by his electric wheelchair[1]
    [1] The joke being that no-one noticed as he convulsed.
  15. Ash@Work
    Ben Blaney Guest
    Amazingly, someone employed me once.
    Ben Blaney, Sep 12, 2003
  16. Ash@Work
    WSotW Guest
    ok ..all from memory so may not be 100% but certainly 95%
    If it's on retention then he has a certificate of asignee (or similar)
    in his name. You pay him the monies, he changes the asignee on the
    certificate to you (must be sent back to dvla) , new cert sent to you
    at your address.
    Note it must be done this way cos the vehicle to which you asign the
    reg must be in the name of the asignee. Also you will need to pay the
    asignement fee etc when asigning to the vehicle.
    Note if the donor reg number is to be retained then this is yet
    another cost and procedure. If you dont retain it, then when you come
    to change and take the personal one off it may not be given the same
    reg! (they will try but cannot guarantee it).This depends on wether
    the donor reg is one you want to be able to re-asign to the vehicle.
    Not sure if you know all about personal reg's but there are lots of
    other rules about assigning to vehicles.
    Most notable is if it's coming from vehicle A to vehicle B then both
    vehicle A and B have to be taxed/moted and insured!!
    Also make sure you insurance company know it's a personal reg and in a
    write-off situ that the reg is to be returned to you.
    Check the dvla personal reg site for other rules etc.
    WSotW, Sep 12, 2003
  17. Ash@Work
    Ginge Guest
    Well, he sold the plate seperately to the car and (I think) got more for
    the plate.. cetainly many more times what it cost.
    Ginge, Sep 12, 2003
  18. Ash@Work
    Ben Blaney Guest
    AOL
  19. Ash@Work
    Alan.T.Gower Guest
    LOT 5
  20. Ash@Work
    Ash@Work Guest
    A winner every time with this one.
    Ash ([:])
    Mario Andretti
