Hi, I've just finished doing my first major service the first test ride was a disaster. The problem has gone away but I'm very curious what it may have been. The bike is a 99 ZX-6R with 60,000 km. This is what I did to the engine: Valve clearance (all good). New plugs. New oil / filter. Carb balance. Clean air filter. This is how it went: Bike idles great. Revving on the spot the revs come down very slowly. Riding through congested traffic bike seems a bit down on power. Traffic opens up onto freeway, there is no power above 4/5krpm. There is not enough power to get over 60 kph! I putt along emergency lane to the next exit and hobble back home at about 30-40 kph rolling where possible. Once home I discover: Fresh air exhaust thingies not attached, only difference is they'd suck from behind the fairing instead of in front. Spark plugs greyish white (indicates running lean?) I found no other disconnected or kinked tubes or any loose connections. I reassemble the bike and try again. Everything is back to normal... All's well that ends well, but I'm curious as to what the hell I could've done wrong? The plugs obviously still work but should they really be replaced after going a bit too hot? Cheers, Duncan.
