penetrating oils tested
Discussion in 'Australian Motorcycles' started by Zebee Johnstone, Apr 15, 2010.
  1. -------- Original Message --------
    Subject: [MC-CHASSIS-DESIGN] Fw: Penetrating Oil
    Date: Thu, 15 Apr 2010 22:04:22 +0200
    Reply-To: MC-CHASSIS-DESIGN Mailing List
    To: <>
    Subject: [MHml] Penetrating Oil
    **** Addendum:
    To: MC-CHASSIS-DESIGN Mailing List <>
    References: <D9ED31AC4E3E4E4C9B2079C298E85B1A@vardo>
    FWIW,
    "However, there was some confusion. The author said ATF-Acetone mix
    -- but in reality it was power steering fluid. In fact, the picture in
    the
    magazine which displayed all the products actually shows a bottle of
    power steering fluid -- not ATF."
    cheers,
    Michael
  2. Zebee Johnstone
    Deevo Guest
    Interesting. I wonder why the more commonly known products in this country
    were missing from the list. I would like to see how CRC, Inox and RP7
    compared. Particularly Inox which has a good reputation amont the workshops
    around my area.
    Depends on the type. Both products are types of hydraulic oils and many
    manufacturers actually use ATF in their power steering systems.
    Deevo, Apr 17, 2010
  3. Zebee Johnstone
    theo Guest
    There are two types of ATF, not to be mixed or interchanged. ATF type
    A is, i'm told, often used as Power steering fluid.
    http://www.secondchancegarage.com/public/306.cfm
    Theo
    theo, Apr 17, 2010
  4. Zebee Johnstone
    ross_w Guest
    ATF is easy enough to get, but try buying acetone without being put on
    some terrorist watch list.
    ross_w, Apr 18, 2010
  5. Zebee Johnstone
    Marty H Guest
    bunnings..
    no problems
    mh
    Marty H, Apr 19, 2010
  6. bunnings..
    no problems
    mh
    Either Bunnings or Supercheap or any paint store
    George W Frost, Apr 19, 2010
  7. Zebee Johnstone
    F Murtz Guest
    Any hardware, paintshops, fibreglass outlets, some supermarkets.
    F Murtz, Apr 19, 2010
  8. Zebee Johnstone
    atec7 7 Guest
    The atf is the working bit the acetone can be bought or substituted with
    gp thinners or turps with success
    atec7 7, Apr 19, 2010
  9. Zebee Johnstone
    alx Guest
    No list of penetration oils would be complete without also adding KY
    or anything relating to sheep, such as lanolin-based lubes (eg my fav
    multipurpose lanotech oils and greases).
    Would KY loosen nuts?
    alx, Apr 19, 2010
  10. Zebee Johnstone
    atec7 7 Guest
    I assume that's alluding to Wellington boots and tawegians ?
    or is it a personal enquiry ?>
  11. Zebee Johnstone
    alx Guest
    Wellington Boots? You have a rubber fetish?
    alx, Apr 19, 2010
  12. Zebee Johnstone
    theo Guest
    If you only want a small amount, it's on your wife's/girlfriend's
    dressing table, in a little bottle labelled nail varnish remover.
    Theo
    theo, Apr 19, 2010
  13. Zebee Johnstone
    Unfortunately most nail polish removers are scented and/or contain
    "moisturising oils" which prevent the acetone from working as a surface
    cleaner (I found this when I bought nail polish remover for clean/degrease
    wooden arrow shafts prior to gluing on the plastic vanes).
    I ended up buying a half-litre tin of straight acetone from Bunnings,
    which should last quite a while since I only use it for that purpose. I
    emptied the nail polish remover bottle, rinsed it with acetone, and now
    use it to hold a small working quantity from the tin.
    BT Humble, Apr 19, 2010
  14. If you only want a small amount, it's on your wife's/girlfriend's
    Theo
    True Theo, but most nail polish removers have oil in them, you have to buy
    the remover without oil
  15. Damn, I missed your post before I sent my reply to Theo
    But, BT, you have to make triply sure that you seal the main container as it
    will find an escape route and evaporate without you knowing and when you go
    to get a bit more from the shed, there is bugger all left.
  16. Zebee Johnstone
    Marty H Guest
    IIRC, most nail polish removers are now Acetone free,
    mh
  17. IIRC, most nail polish removers are now Acetone free,
    mh
    Well Marty, I really wouldn't know
    as I haven't had the occasion to use it
  18. Zebee Johnstone
    atec7 7 Guest
    The enquiry is about your intent so answer the question instead of
    failing to be elusive
  19. Zebee Johnstone
    Marty H Guest
    your wife doesn't use it ?
    mh
  20. your wife doesn't use it ?
    mh
    My wife .....wife???
    she walked out on me , couldn't put up with me any longer,
    Thought that the grass was much greener on the other side of the fence
    What she didn't know, was that someone had sprayed round-up in that paddock
    When she found that the grass wasn't that green, she wanted to come back to
    my paddock,
    but I pointed her in the direction of the locked gate between the paddocks.
    She didn't get back into my paddock and wonder of wonders, I have had great
    pastures and good crops since then.
    No-one to share it with except my two rotties
