Pending SV650 Purchase Advice
Discussion in 'UK Motorcycles' started by curium, Jan 14, 2004.
  1. curium
    curium Guest
    Hi, I'm possibly going to purchase a brand new SV650 (Blue).
    My nearest Suzuki dealer, Colin Collins in Harrow (N. London), has them
    brand new for £3999.
    My previous bike was a CB500.
    I'm looking for advice on any problems with this bike and recommendations
    for an Immobiliser/Alarm to have fitted for a reduction in my insurance
    premiums. What tyres does this bike come fitted with as standard and what is
    the agreed best all weather tyre for it?
    Is there any part of the bike that requires particular attention? I'm a bit
    nervous as all my previous bikes have been Hondas which have been reliable
    and easy for me to perform maintenance on.
    Are there any must have mods?
    Thanks in advance :)
  2. curium
    muddycat Guest
    They do make them in black now, you know. But still a good choice.
    I don't know what they come with over there, here they are fitted with
    Metz4s which are crap. I have BT 010s on my SV and they rock. I have
    gone through several sets of them in the 4 years I have had the bike.
    Change the oil regularly and lube the chain. I have 29,000 on mine and
    its still going strong.
    Depending on your weight, you may want heavier oil in the forks. IIRC
    the bike is setup for someone weighing 135 pounds. I did oil, springs
    and emulators in mine. The only other thing I have done is a full
    Yoshimura RS3 system.
    muddy
    Testing the limits of gravity since 1947.
    icq - 219328929
    muddycat, Jan 15, 2004
  3. curium
    Jeremy Guest
    That is an 'S' model presumably? If not, you can get them at least 300
    cheaper elsewhere.
    Jeremy, Jan 15, 2004
  4. curium
    a sex change.
    darsy, Jan 15, 2004
  5. curium
    dwb Guest
    Indeed - though TBH the concept of Curium on something like GSX-R is
    frightening.
    Still, cheap spares.
    dwb, Jan 15, 2004
  6. curium
    dwb Guest
    <warms up IMANASS number>
    Good choice of bike though.
    S or naked?
    On my 2002 model I had 010's from the start - I did this because of
    recommendations on this group that the standard tyres were 'crap'. Jon later
    purchased an SV650 with the standard tyres and I believe he agreed that they
    were, inded, crap. The OE's were Mez4's - if they are no longer Mez4's then
    flip wibble do.
    So - 010's, or possibly an 010 front and 020 rear - Christofire will be
    along shortly to recommend something similar I suspect. 010's definitely
    suit the bike well.
    Alarm - whatever you can get really - Datatool System 3 seems quite good -
    so either that or if they've got a newer version, whatever that is. Check
    how much discount you will really get though - it may not be worth it.
    Problems? As far as I know the SV is nigh on bulletproof. I had mine 15000
    miles and had no problems at all other then the chain going a bit strange
    but I have since gathered this is me rather then the bike. The oil didn't
    get changed other then at the services and all it got was the occasional
    wash.
    They crash fairly well too - a new fairing panel cost about £120 - not that
    outrageous, unless you're from the North.
    The SV is reliable - they would not sell as well as they do if it wasn't.
    Maintenance.. well... which year are we talking about? 2002 or 2003?
    If it's the carb model then I suspect that will be easier to work on then
    the FI model. I would say, if it's new, service it at the dealer until the
    warranty is up.
    Colin Collins are, on the whole, okay - sometimes.
    I changed the plugs on the 02 and whilst the back cylinder is easy to get
    at, the front is a complete shit which requires moving the radiator and a
    lot of swearing to get it out.
    Scottoiler. The SV also sounds very nice with a race can, but on the 02
    model you have to cut through the exhaust pipe to fit it - easy job though.
    That said, the Scorpion can I got messed up the fueling, causing it to
    lurch/stall at rather inoppurtune moments.
    Double bubble was quite nice too, but only if you're doing miles on the
    motorway really.
    dwb, Jan 15, 2004
  7. curium
    Curium sounds like one of life's natural Bandit owners, really.
    darsy, Jan 15, 2004
  8. curium
    Anne Guest
    Reliability - had mine since March '02, so it's going into its second winter
    of commuting without a hitch [1].
    Tyres - ditch the Mez4s and replace with B010s.
    Mods - on a purely practical front, fender extender and rear hugger keep off
    the crap.
    [1] Is that tempting fate?
    Anne, Jan 15, 2004
  9. curium
    Ginge Guest
    in harsh conditions they do suffer carb icing. thats all I can think
    of.
    Ginge, Jan 15, 2004
  10. curium
    dwb Guest
    Ah true - there is that.
    First time that had happened I'd had the bike a week... caned it down the on
    ramp to the A41 after having spent an or two at Chez Bear Watford and as I
    changed gear going into the roundabout everything went quiet...
    Suspect the memory of my subsequent phone call to Bear might still raise a
    smile were he actually about and not threating bodily harm etc.
    dwb, Jan 15, 2004
  11. curium
    curium Guest
    I assume the FI models don't suffer this :)
    curium, Jan 15, 2004
  12. curium
    curium Guest
    Sorry. Yes it is the S model.
  13. curium
    Ginge Guest
    They do if you put carbs on instead.
    Ginge, Jan 15, 2004
  14. curium
    jsp Guest
    I got mine in June and it's done 4500 ish miles. No problems, but I
    wouldn't expect any yet. The winter has had no noticeable effect on it.
    The original tyres on mine were Dunlop D220 ST, which I think is still
    the standard fitment. They seemed like a good tyre to me, plenty of
    grip etc. (My comparison was 010, 020 combo on a Bandit) However, I'm
    about to replace the rear as it's worn out, which I'm not so keen about.
    Next time around, when the front has had a bit more wear I'm thinking of
    switching to Avons, or going back to Bridgestones.
    I haven't ridden a CB500 since my test, so I can't help there.
    John
    SV650
    Black it is
    and naked
    jsp, Jan 16, 2004
  15. curium
    jsp Guest
    Bad form etc, but I meant to add, if you fit a Scotoiler, I took some
    pics of where the bits go if it's of any use to you.
    John
    SV650
    Black it is
    and naked
    jsp, Jan 16, 2004
  16. curium
    Christofire Guest
    Problems:
    Corrosion - some bits (rear brake arm springs to mind) seem to rust very
    quickly - the brake arm mentioned above rusted in only 3 months. The
    warranty replacement did the same in about 6 months. That's stayed on
    the bike as it works, but just looks unsightly.
    Front forks - see mods.
    Carb icing in winter - thought to be caused by the thermometer for the
    carb heaters being placed above the engine. Routing it to a cooler
    location can help apparently. As you're getting the FI model, this
    probably won't matter.
    Old Gimmers - they come up to you in preference of other bikes and want
    to talk to you about it.
    I'd say they're easy to work on. Done my servicing for the last year -
    now on 30K miles plus, and still going strong.
    Up the fork oil weight. 5W was in mine - try 10W or 15W. I didn't
    bother with this until about 20000 miles though.
    Get a scottoiler, they work a treat.
    Tyres - 010s are the best I've used for confidence, feel and general
    fun. They have let me do the most stuff without complaining or letting
    go. I do like them. I'm currently using Avon Azaro's (ST45/46).
    They're not as sticky and they feel like they're sliding a bit more, but
    they don't seem to be wearing. They seem quite good in the wet. I
    found 020 rears would spin up when giving it beans in the wet, but the
    Avons don't.
    010s will last 3-4K miles front, 5K rear.
    020s will last about 5K front, 8-9K rear.
    Avons - I don't know.
    Metzeler MEZ4s (which came as OEM on my SV) are horrible, didn't grip
    anywhere near like 020's and didn't last much longer than 010s.
    Other than the fork oil and the scottoiler (and tyres and brake pads if
    you're going to be pedantic) my SV is standard. It's a lot of fun. If
    you get one and want to make it more fun look at www.jhsracing.co.uk
    For general advice look at www.sv650.org
    Christofire, Jan 17, 2004
  17. curium
    dwb Guest
    Mine did this too - Castrol Chain wax/some sort of other stuff that doesn't
    wash off too easily seemed to work.
    Strange thing is the same part on the GSXR, which looks identical, hasn't
    corroded at all thus far.
    Does the FI SV even have it? I know the brake arm is gone on the GSX-R's
    now.
    I think it's you as no one did that to me...
    Are you sayng the front spark plug is 'easy'? ;-)
    dwb, Jan 17, 2004
  18. curium
    Ben Guest
    It isn't. On the SV it's mild steel, or similar, painted silver. On
    the GSXR it's alloy. The SV one corrodes under the paint whereas the
    GSXR one won't unless really left in salt.
    Ben, Jan 17, 2004
  19. curium
    Christofire Guest
    Well, I cut my thumb through the tip (and nail) the first time, so I
    quickly devised a way that involved less cutting of hands. It involved
    a few bits of wood (of slowly increasing size to move the radiator)
    instead of one bit as recommended in the suzuki service manual.
    Christofire, Jan 18, 2004
  20. curium
    jsp Guest
    Happens to me too, but then it did with the Bandit as well.
    John
    SV650
    Black it is
    and naked
    jsp, Jan 18, 2004
