Pegaso trail top speed
Discussion in 'UK Motorcycles' started by YTC#1, Jun 22, 2009.
  1. YTC#1
    YTC#1 Guest
    While I was playing on TOGs Triumph yesterday, he was ridning the Peg.
    He recorded a top speed of 106mph. (Naughty boy).
    Previous was 100mph.
    I was impressed and on the way home had a go, but I got heavy wobbles past
    95 (I had removed panniers etc when TOG was playing), and maxed at 101.
    Later in the evening I went for a thrash with no excess gear/panniers. Max
    I could get was 104.
    Just checked bike specs online, max is 101......
    I can only assume TOG managed the 106 while on the down hill chunk of the
    M25 J8/7.
    Looks like that top speed setting will be around for a while then :-(
    (unless I press the reset button)
    YTC#1, Jun 22, 2009
  2. YTC#1
    Jeweller Guest
    Heh, I'm keeping my top speed to myself.
    R100RT
    Aprilia Pegaso 650 IE "The Flying Mythos"
    Formerly: James Captain, A10, C15, B25, Dnepr M16 solo,
    R80/7, R100RT (green!)
    www.davidhowardjeweller.co.uk
    Jeweller, Jun 22, 2009
  3. YTC#1
    YTC#1 Guest
    you can always claim some else did it.
    YTC#1, Jun 22, 2009
  4. YTC#1
    Gyp Guest
    Though don't forget that there's proabaly 10% error on the speedo - so a
    real top speed of 101 will probably equate to about 110 or so on the speedo.
    So you need to try harder.
    On the Zed, when I had 145 on the speedo the GPS recorded a far more
    believable 125.
    Gyp, Jun 22, 2009
  5. Actually, it was on the uphill bit of the M23, after the M25, believe it
    or not.
    The Older Gentleman, Jun 22, 2009
  6. YTC#1
    Jeweller Guest
    I have none of these electronic read-outs on my machine,
    there's no incriminating evidence around to embarrass me.
    R100RT
  7. YTC#1
    YTC#1 Guest
    Momentum ?
    Maybe you need that diet the good Dr keeps suggesting :)
    YTC#1, Jun 23, 2009
  8. YTC#1
    YTC#1 Guest
    Granted, but it has been pretty spot on going past those nice speed test
    monitors they set up around the country :)
    I've found digi speedos more accurate, but plan to test with GPS (all
    bikes). Last night at 40 the XJR showed as 35 on a speed test sign.
    YTC#1, Jun 23, 2009
  9. YTC#1
    YTC#1 Guest
    Ah, the older engine :)
    YTC#1, Jun 23, 2009
  10. YTC#1
    boxerboy Guest
    Is that why the two of you were grinning like idiots and gibbering
    like fools when you got back?
    I kept watching for the "prillia in the mirror all the way home but no
    sign.
    Boxerboy
    boxerboy, Jun 23, 2009
  11. YTC#1
    Beav Guest
    Officer, arrest those two anti-social elements.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 23, 2009
  12. YTC#1
    YTC#1 Guest
    That's normal :)
    Took a while to get packed and off, then stuck at 85->90 most of the way
    back.
    YTC#1, Jun 23, 2009
