PC Hardware diagnosis reqd
Discussion in 'UK Motorcycles' started by Champ, May 25, 2009.
  1. Champ
    I throw myself on the mercy of the FOAK.
    A couple of days ago, my PC just hung. No life from keyboard or
    mouse. So I re-booted it, and it wouldn't POST - I got the BIOS logo,
    but then nothing else. I unplugged the mains lead, counted to 10, and
    plugged it in - this time it POSTed, but wouldn't boot, cos it
    couldn't find a boot sector. Reseting again and investigating the
    BIOS settings found that it had lost the 'system' SATA drive from the
    boot list. So I fixed that, and it came up OK. I set a backup
    running, as I thought there may be trouble ahead.
    Today it did the same thing. Except unplugging the mains for 10
    seconds didn't fix it, so I left it unplugged as I was off out. On
    return, I plugged it in and it POSTed ok, and had the same 'drive lost
    from the boot seq' issue. It's up and running ok now, but I suspect
    there's something serious going on.
    Any recommendations? I spose it's worth taking the cover over and
    checking everything is seated ok. Apart from that, I don't know what
    to do apart from fire up www.scan.co.uk and go looking for a new mobo
    and CPU (which, given that this box is a cheapy I put together 3 1/2
    years ago, isn't the worst suggestion).
    Champ, May 25, 2009
  2. Champ
    Gavsta Guest
    Champ,
    As you have already said, reseat EVERYTHING, without looking at it, Id
    say its a dodgy ram chip issue, but it could be anything internally, up
    to and including a fried motherboard. The fact it boots when cool,
    points at a dry joint on "something".
    Gavin.
    For the road: GSXR600K1
    For the track: <gone>
    Current project: Peugeot Speedfight 2
    For everything else: Citroën Berlingo
    MSN:
    Twitter: http://twitter.com/gavin_wilby
    Blog: http://www.stoof.co.uk
    Gavsta, May 25, 2009
  3. Dodgy Cmos battery ?
    steve robinson, May 25, 2009
  4. Champ
    T i m Guest
    Long shot ... CMOS battery? CR2032 or similar on there somewhere? Pop
    it out and stick the DMM on it (typically 3V).
    T i m
    T i m, May 25, 2009
  5. Champ
    Rick Guest
    Bios battery?
    Rick, May 25, 2009
  6. Champ
    DozynSleepy Guest
    You want one of these new Acer Aspire Revo R3600 jobs. Genuine HD
    capable graphics adapter, Amazon has them listed at £149.
    DozynSleepy, May 25, 2009
  7. Champ
    One of mine was doing the same thing a few weeks ago, except I had to
    jumper the BIOS reset pins to make it post. Turned out to be a duff RAM
    stick.
    Krusty
    '03 Tiger 955i
    '02 MV Senna (for sale) '96 Tiger (for sale)
    '79 Fantic Hiro 250 (for sale) '81 Corvette (for sale)
    Krusty, May 25, 2009
  8. Champ
    ginge Guest
    power it down normally and leave it unplugged overnight to see if the
    problem comes back (cmos battery)
    get a copy of memtestX86 off t'interwebs and leave it running
    overnight to see if there's a failing bit of RAM.
    whip the lid off and check the CPU cooler isn't full of dust as the
    lockups could be the cuase of overheating, whilst you're in there look
    for any caps that look a bit odd (either leaning or bulging) on the
    motherboard - usually machines run ok if the odd one fails but once a
    few go it's game over.
    ginge, May 25, 2009
  9. Champ
    Do such things 'go duff'? I thought that if they worked from new,
    they worked forever?
    Champ, May 25, 2009
  10. Champ
    Several others have said this, so I guess it's worth a shot. I didn't
    realise the battery could hang the computer, mind. And it keeps time
    just fine.
    Champ, May 25, 2009
  11. Champ
    Sadly not, it just seems that way as they generally get upgraded before
    they wear out. They're just like millions of tiny lightbulbs at the end
    of the day, & heat cycles will eventually kill them, even if you scrub
    them in properly.
    Krusty
    '03 Tiger 955i
  12. No, they can go. Google for 'memtest86+' and boot that. If it's not RAM,
    I reckon the MB has had it.
    Chris Bartram, May 25, 2009
  13. Champ
    T i m Guest
    I think the clue we used was the 'left un powered for a while'.
    It can't normally other than by loosing your settings so not finding a
    boot device etc.
    Hmm ...
    Check all the other stuff as well (reseating boards / memory [1] and
    blowing the PSU / fans through with yer airline). Then some burn-in
    tests in the hope it highlights summat.
    T i m
    [1] Remembering yer static handling.
    T i m, May 25, 2009
  14. Champ
    Simon Wilson Guest
    Google for 'bathtub curve' and it should probably explain.
    Simon Wilson, May 25, 2009
  15. Champ
    zymurgy Guest
    Heh. I once hamfistedly sheared a capacitor off completely whilst I
    was installing the mobo into the case. Still working fine 5 years
    later ...
    Paul.
    zymurgy, May 25, 2009
  16. Champ
    er, not identical symptoms at all, then - mine doesn't bluescreen. It
    hangs.
    I've got *plenty* of disk space, tyvm. I really don't think it's a
    disk issue.
    Champ, May 25, 2009
  17. Champ
    Tosspot Guest
    They will fail eventually, iirc on some BIOS you can get it to report
    EDAC checks so you can see the increasing error rate (I might be
    talking bollicks) but I'd certainly, as previous posters have
    mentioned, reseat *everything* and replace the cattery. In all the
    cases I've had where HDDs have gone missing, it's the battery.
    Then I'd sacrifice a chicken or two, that usually works.
    Tosspot, May 26, 2009
  18. Champ
    T i m Guest
    True, however I've generally found that as long as they (RAM) aren't
    taken out by something else dying (typically a PSU) AND they have been
    handled correctly (no static damage [1] and / or connector
    contamination) they can generally outlive most of the other bits.
    T i m
    [1] (As I'm sure you all know) The problem with static damage is it
    can simply weaken components and cause them to fail later on,
    therefore there may be no obvious correlation between the incorrect
    handling and the 'unexpected failure'.
    http://www.static-sol.com/library/articles/ESD_damage.htm
    Second pic of more of the board.
    http://letsmakerobots.com/node/2181
    Real world thoughts on ESD.
    http://tinyurl.com/pmgbbf
    T i m, May 26, 2009
  19. Could be anything like the foak suggested. Also worth trying a new cheap
    PSU, odd reboots, no displays, and dropping ethernet connections were the
    symptoms I had on a mates PC a couple of weeks ago, swapping out the PSU
    fixed it.
    Brownz \(Mobile\), May 26, 2009
  20. Champ
    To follow up:
    - I left the power lead disconnected all day
    - on my return, I plugged it in, and it was dead, Jim. No lights, no
    fan, no drive noise. Dead.
    - I took the cover off, and removed the memory sticks. Plugged the
    power in, and it tried to boot.
    - I hoovered it out, refitted the memory, and I'm typing this on it
    now. (After resetting the boot sequence in the BIOS again).
    So, it looks like it was just a question of re-seating the memory?
    But why is the BIOS losing settings - is that a separate battery
    issue?
    Champ, May 27, 2009
