Pater has been busy...
Discussion in 'Classic Motorbikes' started by JackH, May 14, 2006.
  1. JackH
    JackH Guest
    Went over to see my dad this evening, and sitting on the drive is a nigh on
    mint 1979 XS750.
    28k on the clocks, and the condition didn't seem to suggest it had done
    otherwise.
    He paid... £800, which I reckon for something in that condition wasn't
    really a bad result.
    Sounded nice, too. :)
    The silly old sod is still muttering about getting an old Brit bike as well
    though.
    *sigh*
    JackH, May 14, 2006
  2. JackH
    Hope it's had the gearbox fixed already
    Hog, May 15, 2006
  3. JackH
    JackH Guest
    Said it rides spot on, gears all feel nice etc.
    Very nice nick, anyway... got to be better than some old oil pissing BSA.
    JackH, May 15, 2006
  4. Nice bikes *if* you get a later one with the stronger gearbox. 1979 is
    about right.
    Very trquey and handle quite nicely, but Christ! They're heavy.
    Oh, and don't forget the middle gearbox when it comes to oil change
    time. That's another weak spot. On mine, I went to change the oil in it,
    and a few gear teeth dropped into the draining bowl. I buttoned it up
    sharpish and sold it.....
    The Older Gentleman, May 15, 2006
  5. JackH
    Hmm your a dodgy fucker and no mistake. The XS is now having it's valve
    seats recut and ground and new inlet valves dropped in.
    IIRC it was second gear that gave problems? the 850 had it fixed but
    developed ignition pickup problems in place. Gawd this is all a long
    time ago. So have you seen www.yamaha-triples.org yet?
    Hog, May 15, 2006
  6. JackH
    TOG Guest
    Hog wrote:
    What on earth was wrong with the old ones, or is this just a "might as
    well while it's apart" thing?
    Second gear failed, yes. Asdid the primary drive chain. The middle
    gearbox was another Achilles heel.
    Looking now.
    TOG, May 15, 2006
  7. JackH
    The valves or seats? The inlet valves had been battered by the over
    loose tappets and the seats just looked as if they needed recut as well
    as lapped.
    Hog, May 15, 2006
  8. The 'F' model onwards afair. The 850 was the 'G'. I had the 'F' and it
    gave me no problems at all. Only thing I found was it became an utter
    **** to start from cold as the exhaust baffles rotted out.
    You get used to it. First big heavy bike I had to pick up from a U-turn
    drop; there's a knack to it.
    GS850x2 XS650 SE6a
    Every post contains Nutri-Ceramide-R and Pre-Biotics
    for your reading pleasure.
    Folding@Home Team UKRM
    Grimly Curmudgeon, May 15, 2006
