Painting tank
Discussion in 'Motorbike Technical Discussion' started by Freddie, Jul 26, 2006.
  1. Freddie
    Freddie Guest
    I have a tank that I am almost done painting...I need some help
    regarding the final phases...
    What I have done so far:
    - primed with dura-color primer
    - put about 2 color coats of dura color, sanded heavily for consitency
    and smoothness
    - put another coat and had a few runs
    Today I will sand it again to remove runs and put a last color coat.
    Hopefully all will be ready for a clear. However, I have been getting
    mixed reviews. Some tell me to sand right before I put a clear on. Some
    tell me NOT to worry, as it is just for color coverage, so it does not
    matter if it is a little grainy. I am confused. I can see where it may
    be for color coverage. But maybe it is beneficial to get it smooth? I
    have 320, 400, 600, 800, and 1000 grit available. Please tell me what I
    would need to do after putting on my last coat of color up until it is
    done. As this is where I stand.
    I am intrested to hear your opinions especially those that have a good
    proven method with spray painting.
    Thanks for helping a fellow biker.
  2. Freddie
    EggNChips Guest
    Definitely not an expert but the colour coat should not be sanded unless
    the curing time has been exceeded. The clear coat should be applied
    within a few hours of the base, if this has been extended you will need
    to re-key the base.
    EggNChips, Jul 28, 2006
  3. Freddie
    Freddie Guest
    Thanks guys for the comments, once again I recieved, only one commentor
    stating I should sand, however, the most of you all said NO. So that is
    what I am going with. I have already applied the clearcoat, and will
    update with pictures when I have the end result. This is my first
    project. I definetely appreciate the input!
    Freddie, Jul 28, 2006
