Paging WUN/Bonwick
Discussion in 'UK Motorcycles' started by petrolcan, May 15, 2011.
  1. petrolcan
    petrolcan Guest
    I have a 3 ring gas burner where the middle burner doesn't shut off at the tap
    as the thread has stripped.
    I know that the thread cannot be redone and I'm very doubtful that the holding
    thread cannot be recoiled or whatever.
    The O rings are good as when you push the tap it shuts off the burner.
    Any chance of making a new tap?
    I will sort pics of good and bad tomorrow.
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, petrolcan
    <Dragon's Den Mode>
    I'm out.
    </DDM>
    Sorry mate, that pretty much fits the definition of "safety-critical". I
    really wouldn't **** about with it, get a new one.
    Wicked Uncle Nigel, May 15, 2011
  3. petrolcan
    petrolcan Guest
    Can't seem to get spares, hence asking.
  4. petrolcan
    Paul - xxx Guest
    Have you tried here ..
    http://www.leisureshopdirect.com/caravan/gas/l_id66/caravan_cookers_and_hobs.aspx
    Might not have an identical one but might have something similar that
    could be adapted.
    I've also used another place for bits in the past, but can't find the
    url, have to wait till our lass gets back from her run!
    Paul - xxx, May 15, 2011
  5. petrolcan
    petrolcan Guest
    Wuss! The worst that could happen is that a handful of scouts get hurt :)
    But seriously, this is the affected thread:
    http://petrolcan.me.uk/ukrm/tap/thread.jpg
    http://petrolcan.me.uk/ukrm/tap/thread_crop.jpg (close up)
    and this is one of the working taps:
    http://petrolcan.me.uk/ukrm/tap/thread_1.jpg
    http://petrolcan.me.uk/ukrm/tap/thread_1_crop.jpg (close up)
    I'm guessing that the tap shaft is made of brass? The female thread is fine as
    it will hold a good tap.
  6. petrolcan
    petrolcan Guest
    I have and no luck.
    I did a search a few months back and came up with nothing although a new search
    this morning found these lot(1) stocking them and they've given me a number of
    their supplier
    It's an Italian Foker(2) that no-one seems to do spares for.
    Hurry up.
    (1) http://www.campingandleisure.co.uk/acatalog/foker-triple-cast-iron-boiling-
    ring.html
    (2) I know!
  7. petrolcan
    Colin Irvine Guest
    Colin Irvine, May 15, 2011
  8. petrolcan
    petrolcan Guest
    The Older Gentleman, May 15, 2011
  10. petrolcan
    Get bolt with same thread from fastener suppliers, cut tap just below
    the damaged thread, use new bolt to hold remains of tap in. Glue them
    together if the gas pressure won't always pop it open.
    Krusty, May 15, 2011
  11. petrolcan
    Paul - xxx Guest
    These are the ones we've used before .. they gave great service, but it
    doesn't look like they do Foker stuff. Might be worth a call though ..
    http://www.leisurespares.co.uk/
    ...and these seem to supply foker cookers so might have access to spares.
    http://www.caravanning-online.co.uk/acatalog/foker-caravan-cookers.html
  12. petrolcan
    Beav Guest
    If anyone undertook that job (simple as it appears to be) and the shit hit
    the fan, guess who will catch most of the shit? If you can't even connect a
    gas appliance to the "grid" without having what was once a Corgi Reg I would
    imagine that someone *making* a tap or even repairing one would be leaving
    themselves wide open for a fucking and not a pleasant one.
    I'd buy a new part or if a new part can't be found, a new cooker. They're
    not *that* expensive, are they?
    Beav, May 15, 2011
  13. petrolcan
    Beav Guest
    And if it does?
    Beav, May 15, 2011
  14. petrolcan
    petrolcan Guest
    Oh, I am very aware of the implications if things went tits up. I figured there
    would be no harm in posting on the off chance.
    Cannot seem to find a spares supplier although I was given a number to call
    today so will hopefully get somewhere later in the week.
    New unit is about £140 and that might end up the best way to go.
  15. petrolcan
    petrolcan Guest
    Hmm, gotta be worth a go as it looks like the whole lot is going in the bin if
    I can't find a spares supplier.
    Seems ES didn't pick up your post hence slow reply.
    A few scouts might whinge for a while ;-)
  16. petrolcan
    He won't need to glue them as the bolt won't need to pull the valve
    out.
  17. 'Course you can, just not for anyone else or for money. You have to be
    'competent', defined by not actually blowing up your house.
    Grimly Curmudgeon, May 15, 2011
  18. petrolcan
    boots Guest
    Think we already did that a while back. The OP made the same wrong
    assertion then.
    boots, May 16, 2011
  19. petrolcan
    Beav Guest
    It'll save them from being fucked by priests.
    Beav, May 16, 2011
  20. petrolcan
    Beav Guest
    Or your local scout troop? I'm willing to bet the rules affecting something
    for personal use don't apply when a group of youthful potential victims are
    the ones deemed to be at risk.
    Of course I could well be wrong and if the tap in question *did* cause a
    problem, it'd be Ok because the repairer said he was competent.
    Beav, May 16, 2011
