Paging Wik - R1200RT question.
Discussion in 'UK Motorcycles' started by Salad Dodger, Oct 18, 2005.
  1. Using the patented Mavis Beacon "Hunt&Peck" Technique, Salad Dodger
    Not a problem, I'll take care of that.
    Wicked Uncle Nigel - "Oh Bollocks" said Pooh, having forgotten his lines.
    Wicked Uncle Nigel, Oct 18, 2005
  2. Salad Dodger
    Wik Guest
    Aye, it was, actually. Jolly sprightly for such a big beastie. No aches
    and pains even after several hours of m-way tedium and enough go to keep
    up with the sprotsbike brigade until they decided to push it up past
    140mph. Great engine, mind. Not at all like my 1150 despite the same
    layout. This one's got a balancer shaft and is tuned to make the power
    toward the top end where it makes a quite satisfying bark.
    What really impressed me (and, I suspect, others) was the manner in
    which it could be hustled around in the twisty bits. At one point,
    leaving the Ardennes and chasing Bonners, Daz and Ace at 90+mph down a
    swoopy, wet, Belgian A-road, the rear slid out enough as if to say "Now,
    I've been very tolerant up until now. Much more of those sorts of
    shenanigans and I'll throw you into a hedge, ok?" which was nice.
    Quality headlights (a first on any BMW I've ridden) although,
    apparantly, distractingly bright for those I followed and useful (if at
    first, cryptic) info from the RID (Rider Infomation Display) i.e.
    distance-to-empty, two trips, oil temp, ambient temp, etc.
    Lockable cubby-hole for maps (or, I guess the CD player) in front right
    of fairing plus standard BMW accessory socket (and another under the
    rear seat I seem to recall...?).
    Mirrors were ok but I seemed to see an awful lot of the panniers so with
    a pillion, they may not work quite so well...
    I thought so, but then I was solo and it's not like the GL18 but then,
    few things are.
    Panniers were BMW's latest version of their "System" stuff and seemed
    fairly generous. I got pretty much a whole weekend's worth of Wik-sized
    kit into one and then had the luxury of choosing things like additional
    pairs of shoes and shirts and stuff to put in the other. Plus my MP3
    player, bottles of water, etc. They didn't leak at all, either.
    Incidentally, the one I had didn't have *all* the toys on it...
    ABS? Check.
    Heated grips? Check.
    Heated seat? Check.
    Cruise Control? Check.
    Electrically adjustable screen? Check.
    Radio/CD Changer? No.
    Sat-Nav? No.
    Electonically adjustable suspension? No.
    I reckon this latter one is a bit of a gimmick, anyway. I rode to
    Belgium with the rear pre-load set fairly soft ('cause I didn't think
    about it 'til after I'd set off and I knew not where the adjuster was)
    and it was fine if a little bouncy on the m-way.
    When we got there, I found the adjuster after a quick search under the
    seat I wound it up to something similar to my GS, i.e. medium/hard which
    better suited my *ahem* enthusiastic riding style.
    It was, I feel, even more spacious than the ST1300 and with more
    legroom. The Honda definitely has a more canted-forward riding position
    but the R1200RT isn't anything like as bolt-upright as its predecessor
    the 1150. It suited me fine and I had no real twinges, aches or pains
    at all after a whole weekend's riding. Unheard of for me. Did
    occasionally stretch one's legs on the m-way but then, who doesn't?
    Quite.
    HTH, mate.
    Wik, Oct 19, 2005
  3. Salad Dodger
    Salad Dodger Guest
    Ta. I shall have to get me(us) to my nearest purveyor of BMW's finest.
    Loz? Any recommendations?
    | ___ Salad Dodger
    _/_____\_ GL1500SE-V/CBR1100XX-X/CBX1000Z
    |_\_____/_| ..78875.../...19923.../..31251.
    (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4
    |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11
    \|^|/ ANORAK#17 IbB#4 PM#5 WG*
    '^' RBR 2005: Abandoned - Bronze Award.
    Salad Dodger, Oct 19, 2005
  4. Salad Dodger
    Wik says...
    Umm, adjusting the preload doesn't actually change the spring's working
    characteristics. Upping it would have made the rear sit a little higher
    at a standstill, but the actual spring rate can't be changed that
    easily. All it does is alter the sag to suit larger riders. You'd have
    been better off upping the rebound and compression damping a few clicks.
    Rebound being the more important one, according to Mr Ohlins.
    Lozzo
    Track pixie
    GSX-R1000 K1
    I haven't lost my mind, it's
    backed up to a floppy disc
    that's around here somewhere.
    Lozzo, Oct 19, 2005
  5. Salad Dodger
    Salad Dodger says...
    I don't deal with any BMW dealers, but I hear that Sawbridgeworth and
    Slocombes have good reputations.......if you like that sort of thing.
    Lozzo
    Track pixie
    GSX-R1000 K1
    Lozzo, Oct 19, 2005
  6. Salad Dodger
    Salad Dodger Guest
    I've used Slocombes before - for Honda spares and Daytona boots.
    I wonder if Park Lane have one to try out.
    Ooh - they do.
    | ___ Salad Dodger
  7. Salad Dodger
    Hog's the man to speak to about them, he used to work there IIRC.
    Lozzo
    Track pixie
    GSX-R1000 K1
    Lozzo, Oct 19, 2005
  8. Salad Dodger
    Ben Blaney Guest
    I think you know you're going to end up buying on to replace the
    current Wing.
    Don't you have to be under 14 stone to do a bungee jump? Or is that
    parachute jumps?
    Ben Blaney, Oct 19, 2005
  9. Salad Dodger
    deadmail Guest
    I did a bungy jump when I was pushing 14 stone and there were others
    bigger than I there.
    deadmail, Oct 19, 2005
  10. Parachuting was 14st for ram air canopies but then there's a lot of
    skydiving in the US so maybe it's changed.
    Boots Blakeley, Oct 19, 2005
  11. Salad Dodger
    Indeed. As previously mentioned, it could only easily be lost on
    acceleration, but only by clogging the gixxer down a gear or two, and
    you were never dropping that far back in the reall twisty sections.
    But that prolly says more about you than the bike, given that you
    _were_ losing Kiran on his gixxer at times.
    Heh. Found its limit, it would seem.
    Not so much bright as simply poorly adjusted, possibly due to the
    significant mass towards the rear of the machine. One would hope that
    5 minutes with a screwdriver would sort it.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Oct 19, 2005
  12. Salad Dodger
    Ben Blaney Guest
    Seems so.
    Isn't bungee jumping bad for bad backs, though?
  13. Salad Dodger
    MikeH Guest
    It used to be really bad for the health until they abolished hanging.
    It's only since then that they've realised that
    (a) you need elastic rope
    (b) the neck is not the best place to attach the bungeeeeee.
    MikeH, Oct 19, 2005
  14. Salad Dodger
    Eddie Guest
    How primitive. I thought all modern motorcycles had a couple of twiddly
    knobs per headlight: one for up-down, the other for left-right.
    Eddie, Oct 19, 2005
  15. Salad Dodger
    Yeah, prolly. But not my bike, see, so I wouldn't know.
    _______
    Ace, Oct 19, 2005
  16. Salad Dodger
    Salad Dodger Guest
    You're not helping, you know.
    | ___ Salad Dodger
    |_\_____/_| ..78895.../...19992.../..31257.
  17. Salad Dodger
    Salad Dodger Guest
    Received.
    Ta matey - will reply when I have more of a clue what we're up to.
    | ___ Salad Dodger
  18. Salad Dodger
    Salad Dodger Guest
    Not "get", "borrow".
    Also, I can't see me and her fitting on a KTM.
    | ___ Salad Dodger
  19. Salad Dodger
    That must be students, and a limitation of the available student rigs
    shirley?
    Ram airs come in different sizes - mine was a relatively tame 200 sq
    foot jobbie. Gurlies tended to use smaller ones (for better
    penetration, fnar fnar) and more experienced FS guys tended to because
    they're much zippier.
    Accuracy bods tend to use bigger canopies 'cos they come down slower
    at a steeper angle.
    I guess that a really fat bastard could use a tandem rig solo...
    Pip Luscher, Oct 20, 2005
  20. Quite possibly, it's been a while. I'd give it a go again except for
    the being >14st, being >40, not enough time or money for 2 expensive
    hobbies and being a bit of a wuss.
    That'll be what's used in the land of the free then.
    Boots Blakeley, Oct 21, 2005
