Paging Wicked Uncle Nigel
Discussion in 'UK Motorcycles' started by Nick, Aug 29, 2005.
  1. Nick
    Nick Guest
    I have sorted the stud problem on the Bandit, So I won't be needing the help
    you offered. Thanks Again for the offer,
    Nick
    Nick, Aug 29, 2005
  2. Nick
    Eiron Guest
    Let's have the details? Did you get a man in? Did it take 15 minutes?
    Helicoil?
    Eiron, Aug 29, 2005
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, Nick
    NP.
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Aug 29, 2005
  4. Nick
    'Hog Guest
    If you are still a man of leisure I *might* on the other hand have
    something interesting to work on. 3 ally brackets, wouldn't take long.
    I don't think I have your proper email addy, will you drop me a line
    to stewart at bytel dot net dot uk please!
    'Hog
    'Hog, Aug 29, 2005
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, 'Hog
    Emailed.
    All the various addies in my headers are valid, and they all redirect to
    the account I check regularly.
  6. Nick
    Nick Guest
    I drilled the stud out re tapped the hole and set an 8mm stud in the hole
    with JB weld ( good for 300oC) and used a nut on the stud. Seems to be a
    good repair, holds tight and dosen't blow, took more that 15 mins, but not a
    lot !
    The repair by to the down pipes by Banditmania is a good repair, nice
    welding and a stainless stub, but......, the original stub seemed to be a
    bit of an angle to accomodate the link pipe, and the repair is set straight
    on the pipe, this means that the link pipe and silencer is under a bit of
    stress when the silencer mount bolt is fitted, I was concerned that it might
    blow fron the link pipe connection but one layer of exhaust bandage in the
    old gasget is fine, with a new gasget it would be fine, I'll change it some
    time I'm just glad to get it back on the road.
    Now, how much p/ex for a 1300 B King?
    Nick
    Nick, Aug 29, 2005
